Hillmann wrote:how much does a gallon of epoxy cost? and how much does it cover?
Hillmann wrote:I am just wondering what the cost is using titebond II on canvas compared to using epoxy on fabric or glass since it is glue and canvas is being discussed as a thrifty alternative, I am wondering if it really is cheaper than using an epoxy.
Postal_Dave wrote:This is mostly for Hillman:
West Marine makes a great Epoxy for fiberglass. A gallon of the Resin is $93 and you'll need almost a quart of hardener for $40. Now to cover a whole teardrop, you'll need the fiberglass cloth. 60 inches by 10 yards, (almost enough to cover almost 4 sheets of plywood) is $174.
A gallon of Titebond 2 is $20 at Lowe's. A set of jersey material for a bed sheet for a king size is around $20 from Walmart.
So if you buy 3 sheet sets and 2 gallons of TB2, you're at $100. For Fiberglass and Epoxy, you'd be at $310.
I lined the inside of a cardboard box with a piece of that sheet and TB2, then primed and painted it. 10 days ago I filled that box with water and it still hasn't leaked.
This is a great way to make cheap waterproofing.
To tell the truth, you probably don't need the cloth. at the same time I made the first box, I also made a box without cloth. I coated the box with just TB2 and then primed and painted it. I filled it with water at the same time that I did the cloth lined box. It's still holding water also.
That Titbond 2 is some great stuff. Also, I did an experiment with white Styrofoam and it didn't melt mine. Glues with CA in them, like super glues, will melt Styrofoam.
GPW wrote:Larry, that must be some NICE canvas @15 bucks a yard... I was thinking the 3.00/yd. stuff
The glue can be thinned as much as 75% water and still work fine for attaching the canvas , so you could buy a smaller amount and just thin it ... or make several TD coverings with a gallon ..
By my reckoning 10yds of the cheaper canvas and a quart of T2 should be under 50 bucks ... Solvent (water) from the tap ...
Doesn't everybody save their old sheets ??? Recycle !!!
Got an old Indian blanket, that might look cool !!!
