gullywompr wrote:I don't have any experience skinning foam, so forgive me if I go off the rails. I'd like to ask if anyone has tried paper as a skin? I was thinking that it would easily be saturated by low viscosity epoxy or thinned wood glue. For paper, I was thinking about Kraft paper, masking paper, or even a couple of layers of newsprint. Using a squeegee to drive the adhesive into the paper might make for a smooth, paintable surface. Not sure how the costs would compare. What are your thoughts?
Wonder if vellum would work as peel-ply?Wobbly Wheels wrote:Whatever they seal vellum with also seals against epoxy.
Excellent, thanks.Wobbly Wheels wrote:Newspaper is great. I've found it works really well as an epoxy equivalent of chopped strand mat
Maybe fiberglass window screen cloth? It's cheaper than bidirectional fiberglass cloth and also duck cloth (if my math is correct, it may not be). I realize there are far fewer fibers than regular BID, but I'm wondering what the tensile strength requirements are for a teardrop - intuitively it should be less than the beating that a boat hull has to take.Wobbly Wheels wrote: long fibers are where you'd get the tensile strength/panel stiffness from.
gullywompr wrote: Wonder if vellum would work as peel-ply?
GPW wrote:CO, I think we're all guilty of Overbuilding here
Well, that's discouraging. Perhaps dacron is still the best bet.Wobbly Wheels wrote:'Intermittent' is probably the best way to describe the bond and in the spots where it didn't link there were actually bubbles between the vellum sheets.
