hwff wrote:bonnie wrote:If I'm understanding the foamcoat/bounce method, we would have to have the foamie completely assembled and this would be the final finish? In other words, no applying the finish in sections at different time?
Hmmmm.
Applying it in sections would be easiest, as the Foam Coat/Bounce only has a 20-30 minute work time before it starts to set up. If you will have help applying it, you can cover more area quicker. As far as it being assembled or not assembled - that's up to you. You can achieve a smoother finish if you are able to lay the pieces flat and allow them to dry flat.
eaglesdare wrote:i am not sure if this is even proper to ask, but could a free sample of this stuff be sent out for us to test it? i still have lots of foam out back. i could make some joined foam and coat with this stuff to see how it works.
i have video camera's also, so i could record what i do, to let all the foamlings know and see how it works.
just a thought.
swampjeep wrote:hwff wrote:bonnie wrote:If I'm understanding the foamcoat/bounce method, we would have to have the foamie completely assembled and this would be the final finish? In other words, no applying the finish in sections at different time?
Hmmmm.
if done in sections like this, will it still appear as if done all at once, or will you see a witness line at the edges of the sections?
Quick question on the styroplast. Since you would only have a short window for paint or primer to adhere and even shorter in hot summer time, how about just tinting the styroplast? Can you guys come up with tinting additive or point us in the direction of compatible ones? Be a lot easier to put it on the color you want and be done with it.hwff wrote:If you're going to use Styroplast, just remember that nothing sticks to Styroplast after it dries unless you paint or primer it within a few hours after it sets up.
linuxmanxxx wrote:The foam coat is a cement so if you don't get smooth edges it would be a bit more difficult to seal the foam edges you glue together is what I'm thinking of being an issue. With how light the full cabin is assembled, I don't see why the whole foam assembly couldn't be glued together and then the foam coat applied sectionally on a flat surface as the cabin is flipped around. Uniform no lines or seam issues and guaranteed to have good glue edges. Otherwise if you did do the sections before assembly, I'd recommend to leave an edge around the perimeter with just foam and coat it after glued and assembled to make sure there is glue adhesion and no leaks. Even if it is foam, if it leaks into our sleeping area that totally will not be pleasant on any level as well as if you finish the interior with any wood it wouldn't be any good either.
Even with foam watertight should always be the goal in case you need to temporarily use a foamy boat some day lol.
