Re: Thrifty Alternatives ..Building Foam Campers
Postby OP827 » Wed Feb 22, 2023 11:58 pm
There was discussion somewhere on this board about how to bend XPS foam by heating to avoid kerfing.
Here is a simple way by clamping a fiberglass mesh on outside skin to prevent foam from cracking.
This method does not require heating or kerfing.
Watch this video https://youtu.be/URY3X_3chXQ?t=375
OP827
Images: 405
Postby GPW » Thu Feb 23, 2023 7:13 am
The fiberglass takes all the tension loads on the foam ... ;) Спасибо. :thumbsup:
Postby OP827 » Thu Feb 23, 2023 12:59 pm
GPW wrote:The fiberglass takes all the tension loads on the foam ... ;) Спасибо. :thumbsup:
You are welcome GPW ! :thumbsup:
If I build another one, I will use this idea to bend foam.
OP827
Images: 405
Postby rjgimp » Mon Apr 10, 2023 12:40 pm
OP827 wrote:There was discussion somewhere on this board about how to bend XPS foam by heating to avoid kerfing.
Quite a fancy outhouse! :poop:
-Rob
rjgimp
Images: 7
Postby GPW » Tue Apr 11, 2023 6:55 am
That works , but I wonder what he uses for туалетная бумага ??? :thinking:
Users browsing this forum: No registered users and 52 guests
