Re: Foam TD (build journal)/review added
Posted: Thu Jul 25, 2013 10:12 pm
My awning is made of 3/4 pvc pipe the awning frames are glued up and the cross pieces are left unglued but the fabric of the awning allows enough tension to keep the set up together in use. The awning system is simply strapped down to the frame.
REVIEW
After 2 full seasons and some use in the 3rd season, the little TD has held up very well. Most of the trailer exterior is just as it was the very first day. The paint is showing some dirt but I intend to paint it to match my new tow vehicle. I have used this TD in the temperature range from mid 20 degree to mid 90 degree weather. My exhaust fan is adequate in most temps. Only in high temp/humidity combination do I envy those with AC. The TD has been towed up to 75 mph and towed through torrential rains with strong winds and has remained dry except for this last trip when a very small amount of water infiltrated. The infiltration was traced to a small hole in my vinyl window. I'll replace the window film and that will take care of the problem. Considering I drove through a a blinding rainstorm the leakage was minor. Only current changes underway are painting the running boards and mounting the spare tire to the tongue platform. I love the high stance provided by the boat trailer because of the roads that I travel near some of the kayaking rivers. Some of the campground roads are pretty rough as well.
What would I do differently? Can't think of anything right now.
Pat G
REVIEW
Pat G
