Re: Let's talk Kerfs (curving your foam)
Posted: Thu Oct 09, 2014 12:46 pm
Pike .... they do !!!
or t n ttt for short (tnttt.com)
https://www.tnttt.com/
jgraham698 wrote:I posted a short video on you tube titled " how to bend styrofoam with a compression strap" that people
might find interesting. The foam is 1" esp from Lowe's. My first test piece is 1 1/2 thick by 1 and the last
piece is part of a food tray. For straps I used aluminum flashing, luan , and vinyl sheet. Since making the
video (my teenage children filmed and uploaded it for me), I've bent 2" xps for the tear drop I'm building.
jgraham698 wrote:I started my build about 10 months ago. I'm using a 5' wide trailer, so I bent two halves that were 32" wide and 12' long (8' + 4' pieces epoxied together). Each half was bent over the same form with plywood laid on the form first, titebond glue spread evenly over the entire surface and the 2" xps foam nested in a plywood strap made of two pieces joined together with a scarf joint and end blocks 2 x 4 lumber with 1/2 plywood to make a full 2". The front end was bolted to the form and the other end was pulled down to the back end with cargo straps. Some clamping was needed to get good contact between foam and plywood. I need to clear up something about the plywood I'm using. The product is made by Patriot Timber Products called RevolutionPly and is 5 mm (about 3/16) thick. I bought it at a Lowe's store. Anyways, I left each piece clamped up for a week to let glue dry and epoxied them together and covered the outer surface with polyester fleece material and epoxy. That was as far as I got before running out of good weather. After one winter, spring and the beginning of this summer my roof, that's been sitting on the trailer with no other support than it's ends, hasn't changed except for some bubbling of the fiberglass. I think air escapes from the foam after it's been bent. I don't know how to prove that but it explains better my experiences so far than assuming that "closed cell" means airtight.
GPW wrote:"I feel that XPS rigid foam surface by itself is way too weak to be able to resist the stress and still be attached to foam when under expansions and contractions of the epoxy laminate and foam weakening under the sun heat. “ ....
Huh , what ???
JMHO, if you’re bending foam , HEAT is the way to do it !!!
Toby wrote:I'm going to be building my teardrop in pieces inside my heated basement this winter. When the weather warms up, put it together like a puzzle outside. Unless I've missed a few posts, it looks like kerfing is still the best way outside of heat to get those curves. If I'm piecemealing this build, I need to get those curves prior to attaching them to the TD. Looking over the calculations seemed simple enough but how do I get the inside and outside radiuses to plug in the formula? If it helps, I'm using the superleggera model. My plans have the radius for all the curves, but I'm not sure how to apply only one given radius. Does it apply to the inside or outside? I'll be using 2" foam.
