Fiddlin'Billy wrote:So, how does the wood look after waterproofing? Does it look blotchy or is it a nice wood look. Or do you need to stain it to look nice?
tony.latham wrote:Fiddlin'Billy wrote:So, how does the wood look after waterproofing? Does it look blotchy or is it a nice wood look. Or do you need to stain it to look nice?
It is a shade or two darker than pure poly. Depending on the drinkability of the wood. Not blotchy. I find it really deepens alder.
T
tomhawk wrote:I have a plan to build a foamie and go to Burning Man this year.
I had looked into renting trailers for this purpose from several west coast sites. A common statement was they did not allow their trailers to be used at Burning Man. The stated reason was the alkali dust from the desert being difficult to clean.
A solution might be to wash the trailer inside and out with a hose.
Are there any design features I could build in to my trailer now that would allow this to work well?
I would think many properties of the foamie structure should make this viable. Is water going to damage the floor?
I have been in Nevada that time of year when the air temperature was 90 °F and the dew point below freezing so it should dry out very quickly.
dancam wrote:.... It probably gets pretty dusty ..
scoopburt wrote:Okay. I have read all 173 previous post.
I plan to use the mix and after it has thoroughly dried (at least 2 weeks after fi al application of the mix) apply Raptor Liner to the Exterior.
1) should I rough sand the exterior before applying the Raptor Liner?
2) is there any other prep I should consider before spraying the Raptor Liner?
I have read the Raptor Liner direction and cant find anything contrary to applying on wood. Just not sure if "the mix" will affect the Raptor Liner.
Thanks for you expertise
Scott
There website says it can be sprayed in just about anything other the PE plastic (commonly used on ATVs)John61CT wrote:I thought that bedliner is only designed to spray on metal.
..but if your large / heavy main surfaces are made of wood and thus flexing a lot laterally, I think bedliner might be a risky choice.
