Last night I sanded the shine off of the test sample panels and used spring clamps to clamp them to the edge of the table while I routed the 1/8 inch round over along the cedar edge, letting the clamps dent the face on both sides near the edges. Then I poked at the panel with the end of a clamp to make a pair of dents with a torn edge. Then I used 100 grit on the small hand block to sand a shallow valley, but made sure to also press too hard and chunk out some rough area at one end of the valley. I did all of this at each end of each sample because the plan is to cut each panel in half to get a total of four sample coupons.
I thought it would be a good idea to circle the distressed areas with sharpie to help tell the difference between potential air bubbles and white spackle. Here’s a close up of a dent with tear.
Sanding tear out.
1/8 inch round over. You can also see the slight crease between the foam and cedar that will also get spackle.
Spackle applied. I didn’t go crazy with this (… I’m already crazy).
Okay, we’re getting to the good stuff. I cut two strips of 6 oz BID weave 2 inches wide on a 45 deg bias and two sheets big enough to cover the panel with a little excess. This is the stuff I used: JPS Racing Hull.
I used a paper plate under the cup on the scale to protect against spills. Just as I got done pouring the resin the scale display started flashing -BATT- indicating that the battery was starting to die. Oh Crap! I figured if I shut the scale off it might reset, but then I had to figure out how to reset the zero. Used an empty cup on the plate to reset, and while fiddling with it the -BATT- goes off again. Damn, I don’t have a fresh 9v battery on hand, but when I touched the scale it would go back to reading, so I crossed my fingers and hoped that the -BATT- reading was just a warning and not the end of the road. Sure enough, so long as I was pouring a trickle of hardener it would read, but as soon as I stopped pouring it would revert to -BATT-. Whew. I did 60 grams of resin and 12 grams of hardener. Room temp was 68 degrees F. A little cool but still well within the range for the product specs I was using.
With the techniques that Michael suggested foremost in my mind, I wet the strips out on a plastic shopping bag (not the best choice, but okay for a small test), brushed some epoxy on and laid the first strip along the 1/8 inch radius edge of the cedar. It was really hard to pick the strips up off of the plastic w/o stretching them out and making them go narrow by about 1 inch. I was able to pull them back wider again, but the edges unraveled some and it was hard to keep a really straight edge.
Still, it went around the radius without trouble and I squeegeed out the excess. Next I put the larger precut piece over the main part of the panel, dry this time. At first I let this piece hang over the 1/8 inch radius a tad and started wetting, but quickly realized that I should hold it back from the edge, rather than try to trim over the radius. I caught it early enough to nudge the sheet back a little then finished wetting all the way past the 3/4 radius along the other edge, with plenty of excess cloth (too much really) hanging off.
Then I came back with the second piece of bias strip and capped off the cedar end again. The plan was to lay a second piece over the main panel, as well, but I decided to see if one layer would be enough.
Here it is.
I’m already gaining a lot of confidence and can see improvements from my previous efforts.
Just handling the glass and cutting these small pieces I was already feeling itchy on my arms. Just so happens that we use these Tyvek sleeves at work. I had to put a pair on today to do some sampling, so rather than throw them out, I brought them along. Seemed to help and I didn’t need to worry about getting epoxy in my arm hair (… or arm hairs in my epoxy).
I had hoped to let it get to the firm trim stage so that I could trim the excess overhang with a razor, but it hadn’t kicked off enough after an hour sitting there staring at it, trying not to mess with it, so I decided to deal with it later, probably with a Dremel cutoff tool.
If I had been more organized (mentally) I would have tried another test just using a single piece of the cloth and seeing if it could take the 1/8 radius on a 90 deg orientation, and/or to try some of the fine 90 deg BID tape that I have, but I went “deer in the headlights” instead.
I think I would rather keep things as simple and (relatively) thrifty as possible, so I will wait on buying peel ply or bias tape until I test those other options.
I will get to the canvas tests, too, but didn’t want to bother getting the big roll out, making a spot big enough to roll some out to cut a swatch tonight. In fact I might just go pick up a single yard, rather than fight the big roll just yet.
