Foamie aerodynamics.
Re: Foamie aerodynamics.
Postby GPW » Sat Mar 01, 2014 1:11 pm
LD, that would surely work over a former and stringer frame like the FoamStream ... Good idea !!! :thumbsup: 8)
...and that brings up the idea of building an aerodynamic structure , a framework like an old airplane/blimp , covering it with canvas on the outside, and then spraying (or have sprayed professionally for a better job )the inside with professional spray foam (Not great stuff) ...which would give not only the insulation properties , but considerably stiffen and unify the whole structure, while still giving that vintage canvas over rib “look” ... :thinking: 8)
Postby atahoekid » Sun Mar 02, 2014 12:32 am
GPW wrote:just a rough sketch ... Certainly not an Easy build ... but possible ... :thinking:
Again.... :thumbsup: :thumbsup: You tease us with the most awesome designs. Very retro, very cool. Reminds me of design exercises that car stylists do.
Mel
atahoekid
Images: 158
Postby mezmo » Sun Mar 02, 2014 3:13 am
Use foam cove and beaded planks or strips over
an interior frame like the Foamstream's as well as
prestructured interior fittings/cupboards/cabinets.
But you'd then have to build this tow vehicle:
[Pic file too big to copy pic to here.]
One of Norman Bel Geddes's teardrop cars he designed in the 1930s streamline era.
http://en.wikipedia.org/wiki/File:BelGeddesCar.jpg
From : http://en.wikipedia.org/wiki/Norman_Bel_Geddes
One book of his:
https://archive.org/details/horizons00geddrich
pp 44-63
Cheers,
Norm/mezmo
mezmo
Images: 194
Postby GPW » Sun Mar 02, 2014 5:52 am
Advanced aerodynamics comes with a cost ... more complicated to build ... That shape “could” (possibly) be reduced from a circular cross section to an octagonal cross section, Easier to build and almost as effective... drag wise ... :thinking:
Postby Xanthoman » Tue Oct 25, 2016 10:57 pm
I found this thread while looking up to see if anyone had actually built what I am planning. The rough sketch by GPW is almost exactly what mine looked like! (Save I have the back stay wide and round down more similar to a typical hatch setup rather than tip into a cone tail...). I think I have discovered a method of manufacturing that is easy and effective. I plan on making my ribs with 1/8" ply arc about 1" wide and have it 'T' to the outside of the rib that has a 1.5" wide strip of ply. I then will make it like a cedar strip canoe, but with 1/8" ply; not even bothering to edge glue it, just stapling it to the ribs. (I have a pneumatic stapler...) Once the exterior is formed I will cut out the doors and windows and make their hatch trims and install them. Then have a company spray CCSPF (closed-cell spray polyurethane foam) on the inside about 1.5" deep. I will also have him spray a few of the plywood panels stand alone for my future countertops and cabinets (Just 1/2 thick foam with 1/8" on either side). The inside will have a few pex pipes run for electrical chases prior to the spraying. Finishing the interior was the hard part to figure out, but I think I solved the problem. I will sand it with my 7" sander/polisher and fair it out smooth with 80grit paper. Should go pretty quick; I have a good steady hand with that sander. Then I will mix 1:3 parts Elmer glue:water and take torn pieces of heavy duty rosin paper and paste it over the walls for the finish. I plan to then take a road atlas and cut it up and do the same for the wall paper and make it a living collage of our adventures with pushpins and little pictures all mod-podged to the walls. I may polyurethane it, but if I am going to add on to it over time I may just leave it with Elmer's glue.
The hard kicker I am trying to solve now is the convex window I want on the front top. I want to do an argon filled polycarbonate/acrylic blend triple pane window (acrylic/polycarbonate/acrylic) about 4 foot in diameter in the top front area so we can see the stars at night. I am contemplating the ability to form them into a convex shape through heat guns and mold forms...I think I have solved all the other issues... (Vertical side hatch seals, hatch seals, constructability, trailer attachment, location of everything, size, etc.) Here is a quick Solidworks picture of my rib system. I will post my graph paper drawings soon. I have done further Solidworks depictions on it, but there is an error in the lofting of the surface and I don't have the time to solve it now, so you will just have to imagine that image yourself.
gallery/image.php?album_id=4460&image_id=145106
gallery/image.php?album_id=4460&image_id=145381
Xanthoman
Postby GPW » Wed Oct 26, 2016 5:36 am
Can’t wait to see what you come up with !!! Good luck !!! :thumbsup: 8) :D
Postby rowerwet » Wed Oct 26, 2016 7:58 am
L.D. wrote:what about cuttin the foam into stripes, like lath. then you would be working with a small area and molding a rounded shape should be much easyer.
That is the basicidea of how I build my foam kayak, lots of foam ribs, glued into a stack, then shaped to a smooth curve. It is incredibly strong, and very easy, just messy
rowerwet
Images: 521
Postby GPW » Thu Oct 27, 2016 6:31 am
How about cutting Foam ‘Ribs’ , stacking/gluing them together and just carving it smooth ... Messy , yes, but effective ( FoamStream Nose ) :thinking:
Stack and carve .png (73.58 KiB) Viewed 1131 times
Postby GPW » Thu Oct 27, 2016 6:49 am
Just some pics to stimulate the imagination ...
inside .jpg (60.42 KiB) Viewed 1130 times
Construction Types.gif (35.35 KiB) Viewed 1130 times
Postby GPW » Thu Oct 27, 2016 6:51 am
one more ...
F&S inside .jpg (592.55 KiB) Viewed 1125 times
Postby Xanthoman » Mon Oct 22, 2018 12:16 am
It’s almost two years to the day of talking about this but it is about to come to fruition!!! I graduated school and am now ready to embark on my build. I am moving forward with the narrow ribbing forms with a strip built contour being spray foamed for structure and insulation. I have chosen to do bare minimum ribbing using just hot glue racks to get the shape together and then let the foam do its job. I have solved, I believe, most issues of windows and other fenestrations and believe most facets of manufacturing. Just the dirt within the trenches remains to be found so I am excited to turn some soil! I am unemployed so will be working on it full time to crank it out. My goal is to start Nov. 1 and be campable by Thanksgiving!! Build journal to start soon, I will post a link when I do. (And I will hopefully learn to post pictures on here effectively...) Thanks for all the ideas and inspirations I have poured through over the years...
Xanthoman
Postby GPW » Mon Oct 22, 2018 5:21 am
Xan , Cool !!! Good luck !!!
Now if someone had a HUGE 3D printer that printed with spray foam ... :thinking:
Users browsing this forum: No registered users and 24 guests
