GPW wrote: WARNING !!!! ::: They are DANGEROUS , and put AC on the wire , so it will “Bite you” ..or Burn you ...
Use with Respect and Caution !!!
GuitarPhotog wrote:The difference between engineering and random experimentation is that success is more predictable.
<Chas>
Fred Trout wrote:George, could you explain the specifics on how you used the soldering iron cutter; differences in wire gage / thickness & length kinda stuff. Also, did it do as good a job as the 2x4 gravity fed jigs you discussed here ? Anything else about soldering-iron-cutters that you think would help too. Thanks !!
[Mod - this needs to be a sticky thread, please ! ]
