Page 5 of 6
Re: Making a hot wire
PostPosted: Wed Apr 17, 2019 7:23 pm
by Tyrtill
I made a long cut foam board cutter currently it 4' but I will be trying 8' tomorrow (hopefully not to much resistance)
157978
Using picture hanging wire (or probably .030 welding wire) I made a 5 ft length attached to a board with a screw. On the other end was a bolt that was set below a platform for the foam board. Just put the wire on the line and turn on the juice and you get a nice straight cut.
PostPosted: Wed Apr 17, 2019 8:50 pm
by ghcoe
Good Job! :thumbsup:
PostPosted: Thu Apr 18, 2019 6:12 am
by GPW
A Pivot wire system like that , can also cut out tapered shapes with a template on the other end … :thinking: Check this guy out …. https://hackaday.com/2015/05/14/move-ov ... you-wings/ Any ideas ???
PostPosted: Thu Apr 18, 2019 8:18 am
by Tyrtill
8 FT was a real slow cut ~ 1 minute for an 8 foot cut but it looks just as nice as the other cut.
I did see someone using a template and it made me think of useing shelf brackets or L Brackets to make perfectly straight and square cuts every time but my "by hand" method seems to be giving me reasonable results.
157980
PostPosted: Thu Apr 18, 2019 5:45 pm
by featherliteCT1
Thanks for posting the video ... your method appears to work great!
PostPosted: Fri Apr 19, 2019 6:14 am
by GPW
T’ , for shorter cuts with our bow we use the gravity method laying the wire across the foam , bow underneath , then turn on the electricity and the hot wire just falls through the foam , producing exact cuts every time , and if we want an angled cut we just tilt the foam …
PostPosted: Sun Jun 02, 2019 11:27 am
by Hamilton Felix
This is all interesting. Sounds like it does not take a lot of heat to cut foam.
I have a Harbor Freight "hot knife," but it's rather thick, something I bought to work with synthetic rope.
I was thinking that with the right wire, I should be able to make something to work off of my old Weller D650 soldering gun. I see many others have done so. That is 200 or 300 watts, depending on trigger position. Might be overkill. I wish I knew what happened to my old 100/140 watt Weller 8200 N. I inherited an old Craftsman gun that I think is 120 watt, but it doesn't appear to be designed to replace its tips. Might sacrifice that one to science...
Too bad Weller doesn't offer foam tips. They do make plastic working tips. Oh well, we'll make our own. :)
PostPosted: Mon Jun 03, 2019 6:03 am
by GPW
Ham, getting the heat right is important!!! …. Too little heat doesn’t cut , too hot makes big Wallowing cuts … It’s most practical to make a Bow type hot wire and use some type of adjustable DC power supply ( like an old train transformer) . We still use an old Variac , but that puts low AC on the bow ( dangerous) …
Over the years we’ve cut literally hundreds of Foam wings for model planes …. Once you do a few , you can get great results , and with smaller cutting wires and a pair of templates , you can cut most any shape you want ...the sky is the limit ... :thumbsup:
Ps. our Favorite Hot wire is still Stainless steel Fishing leader material ( solid) … Cuts great , lasts a long time , and it’s cheap and available ;) … Remember you don’t want the wire glowing HOT , just hot enough to melt the foam …
Ps , Don’t do like I did using an AC plug at the wire end ( fits my Variac) , as someone might accidentally plug it in the wall … :frightened: Big alligator clips work great instead … With a wire , polarity doesn’t seem to matter ...
PostPosted: Mon Jun 03, 2019 7:40 am
by Tyrtill
With mine for an 8' cut I'm using around 200 watts (8 to 10 amps at 24v). In the case of the wire I'm using 6-10 Amps cuts pretty well but over that it cuts about 1/8" and if you let it stay put too long it can cut almost 1/2".
PostPosted: Mon Jun 03, 2019 10:52 pm
by Hamilton Felix
LOL! Someone would only plug that directly into 120VAC once! :lol:
I can see how some kind of variable power supply is the way to go. If your cutter is relatively low wattage, there might even be some dimmers that would work. My soldering gun gives you 300 watts, 200 watts, or nothing. Not great options.
I’ll have to poke around in my shop. :thinking: Maybe there’s a forgotten old variac at work... ;)
I like that bow saw design above. I might even have an old bow saw around here.
PostPosted: Tue Jun 04, 2019 4:45 am
by GPW
And just sayin’, my Variac is fused for 5 amps , and we’ve only blown the fuse once in about 30 years … I only turn it up slowly till it begins to cut , that's all ... :thumbsup:
PostPosted: Fri Mar 26, 2021 8:38 am
by twisted lines
Anyone try a variac / soldering gun combo,
Thought’s ?
PostPosted: Fri Mar 26, 2021 9:10 am
by twisted lines
A few are using mig wire;
Neat trick I learned, long scrap’s put one end in a vice the other in a drill and pull tight, spin the wire!
This thread has some casual warnings, so if you are challenged this may be catastrophic
You must take your finger off the trigger before it goes pop.
The goal is to have a firm straight piece of twisted wire :thinking:
I had it break the wire the first time but it was straight, I have done pieces 25 to 30’ long then cut to length for filler wire, guessing around 6 twist per inch, it works very well to get ride of the curl :thumbsup:
PostPosted: Fri Jul 23, 2021 8:04 pm
by twisted lines
GPW wrote:And just sayin’, my Variac is fused for 5 amps , and we’ve only blown the fuse once in about 30 years … I only turn it up slowly till it begins to cut , that's all ... :thumbsup:
I have pondered how and made my first at home, more with time or need :thinking:
First Variac plugged a soldering gun in nothing after bending a wire, blown fuse weard with no spare.
Second one blew the fuse after these test and finishing what I needed :lol: one more +&-
First (Top wire) Left test cut too deep, .043 SS Filler wire;
Second .035 SS Fishing leader, I did what I wanted with the but I think the larger wire let me push harder went faster.
PostPosted: Sat Aug 07, 2021 10:08 am
by twisted lines
Cutting some corner pieces for some electrical addition's (Needed) :lol:
Using this old saw for the outside, and after trying a inside cut; Not so good.
Idea of using this spring set up with Insulators and a pattern, It was a easy way to get several done and test the do I really want one, itch.
Using .035 welding wire That was twisted with a drill, but it breaks when tightening a loop.
