The Big Pink, Foamie !
Re: The Big Pink ...
Postby Spotman » Mon May 04, 2015 1:00 pm
What was the name of the campground? Looks nice there to.
2018 Heartland Terry Classic V21
2018 Toyota Tundra DC
Spotman
Images: 241
Postby tac422 » Mon May 04, 2015 2:24 pm
Spotman wrote:What was the name of the campground? Looks nice there to.
Bob,
The campground isn't a normal campground. :shock:
You can rent the whole park....(all 15 acres including everything) for events.
It'd make an great teardrop gathering ! I'll call you to talk about it. :twisted:
Look here .... http://www.olegilliammill.org/
mill pix.jpg (103.68 KiB) Viewed 2342 times
ol mill park.jpg (137.25 KiB) Viewed 2342 times
tac422
Postby tac422 » Wed May 27, 2015 3:55 pm
I was worried that my circuitry was too simple, so I added a voltmeter to monitor the 12v system. :lol:
There are 3 different ways to power my 12v devices,
1. a built in 12v power supply (115v)
2. tow vehicle power
3. a small 12v battery.
My buddy gave me the meter, it came from eBay and cost about $1.50
tac422
Re: The Big Pink ... still upgrading
Postby tac422 » Thu Jul 30, 2015 7:50 pm
The Big Pink has 2 storage compartments under the bed. They are in the very back, so It's a little hard to access, and was used for seldom used items.
118156
So I thought I'd fix that .... and added an outside access door. There are 2 layers of 2" foam , so I had to cut through 4" of foam.
There was canvas on the inside, outside, and in the middle. The adhesion everywhere was very good.
134680
almost finished .... just have to finish cleaning up. I used 4" angle sheet metal, and screwed into the door frame to provide a solid mount
134679 134682 134683 134681
The door is right next to the power input connector, and I'll keep the jack stands in there, since they get used at the back.
tac422
Postby GPW » Fri Jul 31, 2015 6:40 am
Storage problem solved ... :thumbsup: 8)
Re: The Big Pink ... added a storage door
Postby mikeschn » Fri Jul 31, 2015 6:59 pm
Nice feature. I'll have to keep that in mind!
Images: 479
Re: The Big Pink ... added storage.
Postby tac422 » Mon Aug 10, 2015 7:29 am
The Big was getting a little heavy, so I thought I better remove some foam.
Just kidding... not having easy access to the back storage compartments has always bugged me.
Having solved one side with the addition of the access door, I decided to cut some holes through the interior bed supports to house the canopy.
While there is still some hard to access space on the curb side, I now have easy access to store the canopy, extension cord, jack stands, and other stuff in the back now. :)
tac422
Re: The Big Pink ... storing stuff
Postby GPW » Mon Aug 10, 2015 7:48 am
Just a thought .... when cutting access holes like above , remember the arch , which is a Stronger hole .... :thinking:
Postby tac422 » Thu Aug 13, 2015 6:51 pm
Alas, no room for an arch.... the hole is just big enough to slide the popup tent through.
tac422
Postby mikeschn » Thu Aug 13, 2015 6:55 pm
I like it!!! :thumbsup:
Images: 479
Postby OP827 » Fri Aug 14, 2015 12:29 am
Nice! :thumbsup:
OP827
Images: 405
Postby GPW » Fri Aug 14, 2015 6:02 am
Tac, I was really meaning just round the corners , square intersecting corners build stress risers at that point ... Rounding the corners spreads the load out ...
I’m just trying to use every trick in the book to assure everybody has Maximum strength constructions... :thinking:
Postby Mary C » Fri Aug 14, 2015 7:09 pm
I happen to think that you are doing a great job and now you are thinking like me every inch of space to get used for storage.
Mary C.
Mary C
Images: 473
Postby tac422 » Mon Aug 24, 2015 7:20 am
Mary,
Thank you :D
So we took the Big Pink out for one last weekend before putting 'er away for the winter. Everything is working great.
I did wash it for the first time, after sitting outside for months. Just some soapy water and a cloth cleaned right up .
tac422
Postby GPW » Mon Aug 24, 2015 7:45 am
:thumbsup: 8) :applause: Tac , you have plans for multitasking BP whilst in storage ??? Mini office , man cave , sports Bar ... :beer:
