Working with flashing and beading
Postby ghcoe » Fri Jul 04, 2014 6:07 pm
I have been working with flashing and beading for some time now. I realized that it takes a bit of finess to work with. So thought I would start a thread on how I work with it.
I have been mainly using 2x3 and 2x2 flashing that is available at HD and Lowe's. Flashing can be found in the roofing section. The dimensions of the flashing are exact, unlike wood, so a piece of 2x2 flashing is actually 2" by 2". This works great with the 2" foam since you do not have to worry about material thickness differences.
The beading is used with dry wall. There are quite a few different types of beading. There is plastic, metal, paper covered metal, corner, bull nose (rounded), ect. I have found the best selection at HD, but Lowe's carries the one I have been using which is paper covered metal.
Some examples of how I have used the flashing and beading.
Flashing used as front edge support/protection
DSCF2207 small.jpg (87.45 KiB) Viewed 5960 times
Flashing used as door threshold/frame
DSCF2854 small.jpg (114.44 KiB) Viewed 5960 times
Papered drywall beading used in hatch edge protection
DSCF2110 small.jpg (122.77 KiB) Viewed 5960 times
George.
ghcoe
Re: Working with flashing and beading
Postby ghcoe » Sun Jul 06, 2014 9:02 am
A few more applications.
Flashing used for galley door edge protection and hard points for latch and hinge
DSCF2403 small.jpg (224.16 KiB) Viewed 5915 times
Flashing for bottom edge protection. Beading for galley hatch protection
DSCF2217 small.jpg (102.45 KiB) Viewed 5915 times
Flashing used for shelf edge protection and extra span strength
DSCF2224 small.jpg (106.86 KiB) Viewed 5915 times
George.
ghcoe
Postby Olddog1 » Sun Jul 06, 2014 9:33 pm
ghcoe, I can't see but a few mechanical fasteners and they seem to be at joints. Is the beading attached with adhesive and if so what type?
Olddog1
Images: 15
Postby atahoekid » Mon Jul 07, 2014 12:01 am
As logical an application as that is, I can't believe that I never thought about it as I built the Road Foamie. It would have certainly made certain parts of the build easier.... I'll store this in the back of my skull somewhere for use the next time!!!!
Mel
atahoekid
Images: 158
Postby pchast » Mon Jul 07, 2014 11:46 am
I think flashing used on my door edges may have
improved gasketing on my unit...
pchast
Images: 96
Postby atahoekid » Mon Jul 07, 2014 6:02 pm
You're probably right. One of the things that I think helps create a good seal is a defect free surface. The flashing certainly provides that...
Mel
atahoekid
Images: 158
Postby ghcoe » Mon Jul 07, 2014 6:25 pm
Olddog1 wrote:ghcoe, I can't see but a few mechanical fasteners and they seem to be at joints. Is the beading attached with adhesive and if so what type?
I am using mostly using Great Stuff for flashing attachment. Seems to hold quite well unless you forget to clean off the flashing with alcohol first. I try to handle the flashing with gloves on once cleaned off to keep from reapplying more oils.
For the beading I have been using Gripper, although that may change.
I am using pop rivets at key locations.
George.
ghcoe
Postby ghcoe » Mon Jul 07, 2014 8:09 pm
So to start measure the length you need. Once the length is measured I use a small square to make my cut line. Then take a straight cut tin snip and make the cuts. Quick and easy.
Measure
DSCF3152 small.jpg (132.48 KiB) Viewed 5828 times
Mark with square
DSCF3155 small.jpg (124.65 KiB) Viewed 5828 times
Cut with tin snips
DSCF3158 small.jpg (71.84 KiB) Viewed 5828 times
George.
ghcoe
Postby ghcoe » Mon Jul 07, 2014 8:24 pm
Once cut I check to see how the angle of the flashing looks.
Piece cut
DSCF3159 small.jpg (131.89 KiB) Viewed 5826 times
Usually the angle is a bit obtuse. This will work fine for inside corners. You want a little bit of presser from the angle to keep the outer edges down along the surface you are applying to.
Obtuse angle
DSCF3160 small.jpg (112.81 KiB) Viewed 5826 times
If you are going around a outside corner you will want to bend the flashing a bit acute so that the same idea applies. A slight spring pressure to keep the edges down along the surface your applying to.
Acute angle
DSCF3162 small.jpg (120.18 KiB) Viewed 5826 times
I also try to make the edges as straight as possible. Usually they are straight, but sometimes you will find that they will be bent.
George.
ghcoe
Postby tac422 » Mon Jul 07, 2014 8:29 pm
This is a GREAT idea !! :applause:
I copied this for The Big Pink, but I used the plastic moldings. They worked really well with Gripper.
110038
109916
tac422
Images: 222
Postby ghcoe » Thu Jul 10, 2014 7:52 pm
I have used both Gripper and Great Stuff to attach the flashing and beading. I have found that I like the Great Stuff better for the flashing. Usually I will spray the Great Stuff onto the flashing and then take a piece of scrap foam and mash it down and spread it to cover the entire side of the flashing being glued down. By spreading the Great Stuff it will cut down on the hydraulic effect of the foam as it cures. It will still foam up, but is much more controllable. When applying make sure that the flashing is seated all the way down to the corner. This is were the slight spring action of the obtuse or acute angle needs to be just right. Pictured below is a piece of flashing with both Gripper and Great Stuff applied.
Glue
DSCF2204 small.jpg (109.92 KiB) Viewed 5743 times
Clamps are applied. I only need to apply clamps to one side since the spring action of the angle will hold the opposite side down to the surface.
Clamps
DSCF2406 small.jpg (215.9 KiB) Viewed 5743 times
George.
ghcoe
Re: Vent installation
Postby ghcoe » Sat Dec 13, 2014 10:08 pm
I am going to walk through a vent reinforcement/hard point installation using flashing.
So I have a cutout in the foam for a roof vent and I have a roof vent. The dilemma? I need hard points to screw the vent to on the roof and inside for the garnish. Also in cutting a hole for the vent it has weakened the roof some in that area.
Vent cutout
DSCF3338 s.jpg (83.41 KiB) Viewed 5393 times
The cure....... 2"X2" flashing.
2"X2" flashing
DSCF3339 s.jpg (84.33 KiB) Viewed 5393 times
First I put on gloves and then wipe down the flashing with alcohol to remove any oily residue that may be present. The gloves protect my hands and keep me from getting more oil on the flashing. This will help with glue and paint bonding later.
Gloves and Alcohol
DSCF3340 s.jpg (83.14 KiB) Viewed 5393 times
George.
ghcoe
Postby ghcoe » Sat Dec 13, 2014 10:22 pm
So the vent is made for a 14"X14" hole. I take my measuring tape and measure and make a mark every 14" to make a square.
Marking for the cuts
DSCF3343 s.jpg (79.54 KiB) Viewed 5393 times
Then I take a small square and make the cut lines on one side of the angle.
Marking the cut lines
DSCF3344 s.jpg (79.38 KiB) Viewed 5393 times
On the last cut I mark a cut line on both sides of the angle.
Cut for both sides of angle
DSCF3345 s.jpg (77.64 KiB) Viewed 5393 times
George.
ghcoe
Vent installation
Postby ghcoe » Sat Dec 13, 2014 10:32 pm
Now I take a straight cutting sheet metal cutting shear and make the cuts along the cut lines.
Making the cuts
DSCF3346 s.jpg (79.15 KiB) Viewed 5390 times
After the cuts I then need to make the bends. I used some scrap 1/4" flooring I had laying around to make a simple sheet metal break. I placed a piece on each side of the angle opposite of the cut and clamped them down. Make sure the ends are even with the opposite cut on both sides of the metal.
Simple sheet metal break
DSCF3347 s.jpg (82.42 KiB) Viewed 5390 times
Then I place another piece of the 1/4" flooring on the other side of the cut butting it up to the wood I had already clamped down. Now using the flooring as leverage at the bend I bent the metal over.
Making the bend
DSCF3348 s.jpg (97.63 KiB) Viewed 5390 times
George.
ghcoe
Vent installation
Postby ghcoe » Sat Dec 13, 2014 10:39 pm
So not being a perfect sheet metal break you will not get a nice crisp bend. :(
Not a perfect bend
DSCF3349 s.jpg (108.6 KiB) Viewed 5387 times
But, if you take a flat faced hammer and lightly tap the metal against the wood clamped for the break you can make it crisp. 8) Tap very lightly and evenly so you do not get any hammer marks in the flashing.
Perfect
DSCF3351 s.jpg (96.35 KiB) Viewed 5387 times
You should get something like this. :thumbsup:
Finished bend
DSCF3355 s.jpg (91.86 KiB) Viewed 5387 times
George.
ghcoe
Users browsing this forum: Bing [Bot] and 7 guests
