andreuther wrote:Time to end this thread. ABC supply told me today that the pink and blue foam makers are no longer allowed to sell to CA. I will be building with wood and that suits me perfectly as I refuse to use styrofoam. Maybe I will do a foamie when I move away from CA. I will be starting a build journal very soon. Thanks for all the advise!
andreuther wrote:Yeah I have seen it around here and it has a reflective layer glued to it that is very hard to get off. You might be able to heat it and then remove it. My biggest issue with it is the price!!! At $33 a sheet I would prefer to build with wood. In my my I would choose foam for a budget build and that stuff brakes the bank in my budget. If you do test it let me know how it works out.
andreuther wrote:Thanks for the info, I will look into this. Could be another game changer.
