aggie79 wrote:vigilant1 wrote:GPW wrote:"(food for mold, etc when wet) “ .... Hence the need for the waterproofing .... OK ???
Okay!!!
Waterproofing is
certainly important.
Observation: Almost every wood-framed factory trailer leaving the showroom is 100% waterproof. Many of them have rotted through after a few short years.
What would belt and suspenders look like?
- Keep the water out (protects the contents and the structure of the trailer)
- Design and build so the trailer can dry quickly when water does get in (no materials or assemblies that trap liquid or vaporous water)
- Avoid materials that fail when wet.
But, that's admittedly an ideal approach. In real life, compromises are usually required if we want to make progress.
Mark
If I can add another point to your list, I would say "use interior finishes that do not seal in any water or vapor intrusion".
Even in Along the southern coast - assuming termites or hurricanes didn't finish them off - historical wood-framed homes with wood siding have lasted 100 years. It was only till "tight" homes were built that problems started arriving. Even water-logged boats last for centuries.
Aggie, I agree with your expansion on my second point. If the wall assembly can't dry to the outside, then it needs to be able to dry to the inside (and there needs to be a vent open or another way for the interior air to exchange with the outside).
I suppose If a trailer was going to be heated and cooled for most of its life (like a house typically is), then we'd need to concern ourselves with which way the water vapor pressure was going most of the time and we'd put the most restrictive vapor barrier on the correct side (usually toward the side that is expected to be warm the most. For those of us in "heating climates" that means on the inside of the wall assembly, so we use batts of insulation with a vapor barrier toward the inside of the home)). But if a trailer isn't going to be occupied all the time, it's probably sufficient that the water that gets into the assembly (through leaks, through condensation of water vapor that travels through gaps either way, or through transpiration of water vapor directly through the materials) has a way to get out, and it probably doesn't matter if it goes in or out.
So, a lead-up to a science project from this newby: Has anyone figured out the "perm rating" of the unique materials often used in TnTTT construction? Is it of interest? That would give us a good idea if drying can be expected to occur. If that's not known, I'll start a new thread to get some solicitations before I go any farther with a homebrew experiment. Ideas for testing would include:
--- 1) Thick uncorrugated cardboard (aka chipboard) treated with "the mix" (75% mineral spirits/25% polyurethane sealer)
--- 2) Same as above, but with fabric and TB II on the surface
--- 3) 3/4" plywood treated with "the mix" (as used in floors, etc)
--- 4) Fabric with TB II (not attached to anything)
--- 5) 1" of XPS with FG and epoxy
Controls (so I can adjust any results I get with published numbers for known standard materials that have published perm ratings)
--- 1" of XPS foam
--- 3/8" drywall
--- Aluminum foil (zero perm)
I've got a stake in this, as I am thinking about building with a painted FG/epoxy skin (outside), 2" XPS foam, FRP (fiberglass reinforced panels) on the inside. While that has some good points, it might not dry well
when water does get inside.
Mark
