GPW wrote:Consider this , even if canvas is pre-shrunk , can it not be stretched again when applied wet , and then shrink again ...
GPW wrote:As we found , the real trick using un-shrunk canvas was to leave enough extra material on the ends so you can trim it when it’s dry ... If you fit/cut it first , it may shrink beyond where it’s supposed to ...
