the vanity plate I want...
mikeschn wrote:Some of your bends are too sharp for a foamie unless you start kerfing...
viewtopic.php?p=1137445#p1137445
Ned B wrote:At the risk of being over-confident (again) I'm going to pick up the plywood tonight, I'm going with PT 3/4 for the base, then a raised floor to build out over the wheels. Hopefully that will let this be useable for Lori as well. Still aiming at a straight lines design, but to help combat her claustrophobia I'm working up a lifting roof a-la the rockhopper.
KennethW wrote:If you are going for light 3/4 base is over kill. 3/8 is all you need as you will be just laying on it.(not walking)
