Generic foamie plans
Re: Generic foamie plans
Postby rowerwet » Thu Aug 17, 2017 6:50 am
From removing the fabric I know that you get a better adhesion to the foam because the little holes in the foam each end up with a dot of glue inside.
This locks the glue into the foam. Making a better bond than just gluing to the top layer of foam.
Peel testing proves this.
For foam to foam joints, I also perforate the faces to be glued, I haven't been able to break one on a joint, so I think this makes the foam joints tougher.
The foam breaks next to the glue line.
rowerwet
Images: 521
Postby GPW » Thu Aug 17, 2017 6:15 pm
Thanks Row , great advice !!! :thumbsup:
Users browsing this forum: No registered users and 26 guests
