Since it looks like wood is still a practical ( and easily accessible) framing material and does find some good use in a Foamie trailer construction. We must find a way to make it completely waterproof ... I had an idea ...
Saw some large PVC pipe , must have been 8” dia or even bigger... Cap one end off , prop it up on something so its on a 45 degree angle , Then fill it half way with “The Mix” , and insert a couple boards till they are covered completely with "the mix" ... How long it would actually take , to become Mix-logged’ I don’t know , but ideally it should fill every little end grain and pore in the wood ... making the board “plastic” and impervious to water absorption ... Sounds a bit far fetched, you could probably just get a big tray or Tub and soak it in that .... Whatever !!! The idea is to fill the tubes in the wood , “plasticizing”, eliminating many problems in the future , and it should even cut better , like cardboard treated with "the Mix" does ... Note : You may find it easier to cut all your pieces to length first and soak them as “shorter" pieces instead of full length boards , that way , logically , the Mix could penetrate better and not have to go so far to Completely fill the tubes...
The idea , soak the wood in the Mix ( or Thompsons/whatever you like ) as long as it takes to really do some good ... Just another idea for improving the quality and Durability of our trailer builds ( even non Foamies ) . I’m sure everybody will come up with their own ideas of how they want to do it ...
