Hi I'm looking for the thread where everyone says what materials and methods. I'm about to glue some foam to foam and forget what to use.
Thanks, Mike
mvankanan wrote: Thought about using the latex caulk too, forget who used it, was tempted but it's my first foam build.
Mike
ghcoe wrote:mvankanan wrote: Thought about using the latex caulk too, forget who used it, was tempted but it's my first foam build.
Mike
I have been using the latex caulking in my build. It seems to set up a good bond once dry to the touch on the edges, but does takes a long time to cure completely through. I like using it now better than GG or GS. Mostly because it does not foam and create a hydraulic lift or push on the parts being bonded together or foam out in places that you need to clean up later. It is also more economical than GG and GS. Good luck.
GPW wrote:M, if it’s any easier , you can do all the insides flat on a table , and then assemble them , the fabric does not interfere with adhesion and may actually help , and you can trim it off neatly on all the assembly edges If you want ... and we’re still big on using “reinforcing strips" , which help the inner and outer skins tie together better , the the walls, floor , and roof as a single unit ...
Technically , you could cover each panel inside and out , and then glue them all together as a unit ... Many ways to build a Foamie trailer ...
Won't you be mixing different adhesives, titebond II for the fabric and something else GG for the foam, any problem with that?
I'm assuming you don't paint till after.
This could be a time saver, but I think I can build it as a three sides box and then add the fabric and run it up the sides in one shot, maybe do the top seperate.
You know , it’s easy to make a scale model out of recycled corrugated cardboard ( 1” = 1’ ) ... Great way to get a handle on things ... Cheap and fun ( great rainy day
activity )
mvankanan wrote:
How long before you can apply the fabric?
I never worked with GG, will that fill little gaps, or do the surfaces have to be touching completely, like edge gluing of wood? It seems that the caulk would handle small gaps, and gouges pretty good. I'm talking about less then 1/16" for several inches.
Mike
