ghcoe wrote:The only caulk I have use is the Dap Alex Plus. Only because I have worked with it on many other projects and have a feel for how it reacts to different applications. I have glued flashing to foam and then had to separate it at a later date. The foam literally came off in big chunks with the flashing.
Hi George, I used dap plus. I expected it to be impossible to separate too!
Did you happen to take a look at the separation point. Did it look like the caulk did not bond or did you notice a thin layer of foam still attached. If the bond failed you would not see foam on the caulk. If there was foam then the bond was good and the weak point was the foam.
I scraped caulk off of both pieces. All of the glued surface was covered completely, all the little holes from that roller thing where full.
Also, when I apply the caulk I apply a liberal amount so it will fill in any voids when the two pieces are pressed together. Make sure you go edge to edge on the glued edge too.
I chose the caulk when I first read about it fill any possible voids, I also blue tapped alongside the glue line, so squeeze out wasn't a problem, didn't have to scramble around cleaning it, and bumping into the glue up.
Bad glue? The squeeze out didn't skim over for the first two days under the tarp, the tarps more like a car port, I walk under it,so it's not right on top trapping moisture? It only took a couple of hours to start to skim over once it was in the sun. Once it was dry, at least 48 additional hours, I unclamped it but left the top spacer deal in place on top. We then moved it to the top of the car to get some final measurements. We where as careful as we could be until the first section lifted up.
I also pushed in along the glue line, between the clamps, before unclamping, there was no movement.
I think the foam may have moved a little, the bottom returned to shape. I may have over clamped it? What happened
Good luck.
The glue up of the bedsheets to the interior sides and bottom seemed to work ok, I also glued it to the surfaces that will get glued when it's glued togeather, so I will be gluing two glued fabric surfaces together!
I did read that this may work better! I'll try to get the top cut and covered, and then try to get some paint on the majority of the inside of the panels,keeping well away from where I will glue. The top is two pieces, plus a carved nose piece, I'll have to glue up, but want the thing on the car for final fit.
I followed rowerwet's instructions from instuctables, went great, except I was worried about getting enough on, seemed to use more then I thought, trying to get those little holes filled as he described. I sanded and used the roller on the foam. I ended up with some glue through, I didn't want that but I really can't have it come loose.
So how do I glue it all together to get the canvas on? I'm going to use pl premium, unless someone has a good reason not too, like it will eat through the TB11
I'm going to spread it on fairly thick and lightly clamp it, maybe do some of Rowerwets glue bolts?
Hopefully that will let me get the canvas on. I'm not sure the surfaces are close enough to use GG or TB11, there not bad but there is enough variation, and both of those glues say they don't fill voids. I thought that the caulk would do all that, it should have, I thought it was pretty good idea, still do. Anyway I hope the PL will get me through this. Getting at least the majority of the top on in the initial glue up should hold it together better.
Mike
I'm out of time, there's a chance I wont even get this done in time for our trip, leaving the 24th, what a bummer that would be
