foamie wall to floor attachment options ?
Posted: Tue Oct 25, 2016 7:08 pm
With in the next few week I should be thinking about attaching my 2" foam walls to my plywood floor base. My plan has been to take 2"x2"s and space them 2" inboard from the outer edge of the plywood. Then glue the foam along the floor surface ,and the vertical surface of the 2x2's.
But I'm open to hear your ideas. Since this is my first Foamie build. I would like to hear from those of you that have built foamies, and know what works the best.
My ttt will be 116"Lx76"Wx72"T. I may use some 2x2's for vertical wall support and roof spars ( as an external frame work skeleton)
I got the idea for the 2x2 wall attachment from a post in the general board index. The post was more about plywood walls. But thought it should work for foam also.
