What adhesive or glue to use?
Re: What adhesive or glue to use?
Postby ghcoe » Fri Sep 22, 2017 6:46 pm
Test #2 is finished. This test actually allowed a 6 day cure time.
Test #2
George.
ghcoe
Postby ghcoe » Fri Sep 22, 2017 6:52 pm
Loctite Power Grab.
Again I found the Power Grab to be lacking in Power or Grab. The break was easy to achieve. Product had dried well around the edges but was still a bit sticky in the center. With more time I am sure it would achieve a full cure, but I do not think it would help much with the Power Grab :thumbdown: .
Loctite Power Grab
George.
ghcoe
Postby ghcoe » Fri Sep 22, 2017 7:51 pm
Loctite PL 300.
This product was a bit harder to achieve separation. Again the edges were dry, but the center was still quite wet. I believe with a longer dry time this product would achieve a good bond just by the effort it took to separate with just the edges dried . :thinking:
Loctite PL 300
George.
ghcoe
Postby ghcoe » Fri Sep 22, 2017 7:57 pm
Gorilla Glue Construction Adhesive.
OK, once again the Gorilla Glue Construction Adhesive showed it's stuff. This took quite a bit of effort to break. In fact, as you can see, the glue line did not fail and it was the foam that gave away. That is how much effort that had to be applied to snap this block in two. Product once again was dry all the way through. I like the fact that not only does it dry fast, but it also bonds to the foam quite well. :thumbsup:
Gorilla Glue Construction Adhesive #1
Gorilla Glue Construction Adhesive #2
George.
ghcoe
Postby ghcoe » Fri Sep 22, 2017 8:01 pm
Alex Plus.
Again I found that Alex Plus achieved nearly the same bond as the PL 300. The break point seemed nearly the same. Edges where dry, but the center was like a clay constancy. I believe that it was drying faster than the PL 300 too. Again for the price and such similar results I think I would just stay with Alex Plus. :thumbsup:
Alex Plus
George.
ghcoe
Postby MtnDon » Fri Sep 22, 2017 10:22 pm
Small wonder that Loctite Power Grab All Purpose did not work well. The tech data on that one states one surface must be porous. Foam to wood/plywood/OSB works very well but foam to foam, No.
MtnDon
Images: 24
Postby ghcoe » Sat Sep 23, 2017 7:17 am
This is just a test for foam to foam construction. Non of these products, as well as standard Gorilla Glue and Great stuff, have a recommendation for a foam to foam bond, that I can tell.
The Power Grab does mention Foamboard in its list of products that it works with, as does the Gorilla Glue Construction Adhesive and of course the PL 300 which is specific to foamboard use. I had different results from all these products in this test. Some worked well and some worked not so well.
I might also add that the Alex Plus is not even sold as a adhesive let alone recommended for foam bonding, but as a crack and seam filler. Which in my test seems to bond just as well to foam as the PL 300 which is a specific product for foamboard. For the price I would op for the Alex Plus. Would the PL 300 work better once a full cure was achieved? I don't know. That is another test if someone wants to pursue the results.
So you see that this was a test for first hand experiences with different products to try and figure out which adhesives work the best for me. I am sharing my experiences with others so that they can be more informed with their purchases. I encourage others to do tests of their own to prove out what will work for them. There really is limited information about foamie construction so tests like these are needed to help future foamies. In my case I found you had to think out of the box to overcome certain obstacles, such as using Alex Plus as a adhesive. Recommended? no. Works, yes.
George.
ghcoe
Postby ghcoe » Thu Sep 05, 2019 9:46 pm
bump
George.
ghcoe
Postby Postal_Dave » Fri Sep 06, 2019 12:00 am
Thank you for that information and your good work. It's a timely reminder. :thumbsup:
I tried that foamboard adhesive in my build. I didn't like it either.
Never argue with an idiot. They will bring you down to their level and beat you with experience.
Postal_Dave
Images: 73
Postby John61CT » Fri Sep 06, 2019 6:27 am
Some say Liquid Nails does the job.
Not sure if they would react to any foam types, but 3M 5200 and Sikaflex 292 are both incredibly strong, also permanently flexible sealants used below the waterline for fixing keels and sealing through-hulls on boats.
There is a Fast-Cure 5200, cure time is significantly reduced to tack-free in 1 hour and fully cured in 24 hours.
Spiking holes or scribing channels into the foam for a 3D / 90° pattern?
3M Super 90, but of course only 2D flat-to-flat bonding.
John61CT
Postby tony.latham » Fri Sep 06, 2019 8:53 am
My opinion? That stuff is junk.
T
Postby DaddyJeep » Wed Dec 18, 2019 1:51 pm
I just have to comment to keep this in "my posts". good stuff
My big hybrid toy hauler with lots of curves build viewtopic.php?f=50&t=69618
155894
DaddyJeep
Images: 65
Postby JagLite » Thu Jan 09, 2020 4:47 pm
Excellent information!
Thanks for the testing and results. :thumbsup:
ATTITUDE ~
The difference between
Ordeal and Adventure
JagLite
Postby skyl4rk » Fri Jan 10, 2020 9:31 am
Have you tested epoxy?
skyl4rk
Postby ghcoe » Fri Jan 10, 2020 9:52 pm
skyl4rk wrote:Have you tested epoxy?
No. I like foamies because I can use low toxic materials so I usually stay away from the two part stuff.
George.
ghcoe
