Polycrylic and canvas?
Postby stepcut » Mon Mar 19, 2018 11:58 am
Has anyone tried using polycrylic instead of wood glue? I know the RC crowd has been experimenting with polycrylic and fiberglass.
https://www.youtube.com/watch?v=WuEHe6cmnp4
In that use case, polycrylic is cheaper, lighter, and easier to work with than epoxy. But not as strong or puncture resistant. Though, for 50% the weight you still get 60% the strength.
A gallon of polycrylic is around $50/gallon. So it is definitely more expensive than glue+paint.
In my case, I am building a foamie boat and wondering if polycrylic might be a good choice for the parts of the boat that will be below the waterline.
Anyone have thoughts or experience? I searched for polycrylic but did not get any hits.
stepcut
Re: Polycrylic and canvas?
Postby Pmullen503 » Mon Mar 19, 2018 12:35 pm
For a boat I'd use epoxy.
Unless this is just a test and longevity is less important than initial cost. I'd use TB2 or 3 and lots of paint with canvas. Canvas will soak up a lot of poly. Poly will be easier to work with with fiberglass cloth.
I'm one of those RC guys that uses Poly and lightweight glass over foam.
Pmullen503
Images: 58
