All steel work completed, fenders and tongue finished and painted. One coat of primer, and two coats of rustoleum gloss black. Floor completed, I went with OSB cause it’s cheap. Everything soaked really good with the mix. The underside will be sprayed with expanding urethane foam, and undercoated, so it will plenty well protected.
Ready to start some walls!
Re: And so it begins!!...
Posted: Sun Jul 21, 2019 6:04 am
by GPW
Looks Good !!! OSB treated with the mix is very durable ...
Posted: Sun Jul 21, 2019 11:11 am
by MatBirch
GPW wrote:Looks Good !!! OSB treated with the mix is very durable ...
That’s what I’m banking on.
Posted: Sun Jul 21, 2019 11:57 am
by GPW
MB , consider this … my OSB floor which I forgot to apply the mix to , lasted for 6 years …and then it didn’t fail, just got a little “soggy” ... And that was repeatedly being soaked Every day with the morning dew … You’ll be Fine !!!
