Page 4 of 5
Re: Truck camper build.
PostPosted: Thu Sep 19, 2019 9:37 am
by dbhosttexas
GPW wrote:DB, where’s that sketch ??? :o We usually reduce photo sizes on our photo software “ View” in tool bar , “ Tools” , “adjust size “ ( 600X 800 ) works well for this site … Good luck !!!  :thumbsup:
Well it was here yesterday. It would appear this forum is not Google Photos friendly... Let me reduce the photo size in GIMP and upload it to the gallery... I was trying to avoid that.
Here it is, I hope...
PostPosted: Thu Sep 19, 2019 9:06 pm
by pchast
That works nicely. Thanks.
PostPosted: Fri Sep 20, 2019 4:40 am
by GPW
That’s very Nice layout !!! Lots of room for your “stuff”. :thumbsup:
PostPosted: Fri Sep 20, 2019 5:49 am
by RJ Howell
So then the futon/couch is also 'over' the rails? I may be catching up to what you were talking about before (sometimes I'm slow..).
PostPosted: Fri Sep 20, 2019 11:34 am
by dbhosttexas
RJ Howell wrote:So then the futon/couch is also 'over' the rails? I may be catching up to what you were talking about before (sometimes I'm slow..).
Yeah, and nothing to apologize for. I am having issues with getting the image up here, finally gave in and created my own gallery here. Not what I wanted to do. I like having my images centralized in google, but it doesn't work well here...
I think I am going to do some experiements on process, dip my toe in as it were. I have done Polyiso foam with polyester resin / fiberglass, I am going to try samples with PMF over XPS, and see if it meets my needs. If it does, I can continue the design...
I know this might sound odd, but I am thinking especialy on the support structure at the back that has to suppor the door, and AC, I will build that from 2x2 structural lumber, using mortise and tenon joinery. I know the joinery is much fancier than most folks would do, but I am looking for maximum strength with minimum weight and potential for failure, and hey, at least I am not talking about using locking miters!
PostPosted: Fri Sep 20, 2019 12:10 pm
by RJ Howell
Light dawns on marble head!! I follow now! That opens up a huge area of storage or your water tanks you've been talking about! :thumbsup:
A fella from another group sent me some samples of what he has done with making SIP's with probably the foam you speak of. He said it didn't work as well for him with XPS.. He also sent me a sample of fiberglass molding he formed and gel coated. That's really nice and he suggested I go that way for my lift-top on my ultimate build. I'll watching for you posting on your trials with fiberglass and foam! :roll:
Love to see your interior layout, even if it's still design stage! :)
PostPosted: Mon Sep 23, 2019 3:07 pm
by dbhosttexas
Well, after a wet and wild weekend, I am starting to give a bit more thought to the camper design. Since you now get the thought process behind the folding bed. I am experiementing with ways to evvectively pick up from / fill to 4 @ 7 gallon Reliance AquaTainers at once. Either that, or I have to go way over my intended budget and grab a dedicated water tank. I want to separate that off, and drop in a removable cabinet to with areas to organize the stoves, cookware, and other misc camping gear.
For now though, I think I should concentrate on the structural design to support the back of the camper, the Air Conditioner, and the door.
PostPosted: Tue Sep 24, 2019 4:39 am
by GPW
DB, and the pontoons and snorkel …. :o
PostPosted: Tue Sep 24, 2019 8:17 am
by Tyrtill
It isn't but if you make a share link and copy it here https://ctrlq.org/google/photos/ it will spit out a link that you can use. [fimg=800,600]URL HERE[/fimg] to get the pictures to display at a reasonable size. Sometimes you need to use 600,800 depending on the orientation of the picture.
I've always wanted to do a truck camper.... but then I'd have to buy a truck.
PostPosted: Tue Sep 24, 2019 1:47 pm
by dbhosttexas
LOL, I'm sure!
I have a truck, and honestly, as much as I love my truck, I am wishing I had bought a different one. I bought a lease return 2004 F150 XLT 4x4 Supercab with the 5.4L 3V engine in early 2006. I was VERY happy with the 2000 Ranger it replaced, but I was single, and Dating with family in mind, I wanted a full size extended cab truck to be able to haul wife and kids around as well as cargo.... So I opted to go up in size to the F150... The engine in this truck tells me Ford forgot how to do what should be simple for them things, like design a durable V8 engine, and spark plugs etc... If it wouldn't absolutely kill the suspension, and was reasonable and legal to do so, I would happily do a Cummins 6BT swap into this thing... Everything else about this truck has been great, but Lord help me the engine is awful.
PostPosted: Tue Sep 24, 2019 4:20 pm
by RJ Howell
dbhosttexas wrote: I bought a lease return 2004 F150 XLT 4x4 Supercab with the 5.4L 3V engine in early 2006.
Funny,I have the 2004 V6 version. I can't kill the engine. Living in the Nor'East it's the body rust that's killing me! :shock:
PostPosted: Wed Oct 09, 2019 11:05 am
by dbhosttexas
So at least temporarily, I am putting the design on pause, and working with a friend that I believe I have mentioned before, that does boat builds / repairs, and has firsthand experience with fiberglass over foam builds, most specifically poly resin / fiberglass mat, and XPS foam. The key according to him is using lots of Elmers wood glue over the foam to completely seal it before applying the fiberglass mat / resin.
PostPosted: Wed Oct 09, 2019 11:13 am
by tony.latham
Why not glass cloth and epoxy? It's been used that way directly on XPS foam in the aircraft word for at least thirty years. The epoxy adheres to the foam and would be much stronger than a layer of polyester/glass that isn't bonded to the foam.
:thinking:
PostPosted: Wed Oct 09, 2019 12:18 pm
by dbhosttexas
:thinking:
That will be tested as well... But the cost differential between poly resin, and epoxy resin adds up quickly. Unless someone can recommend a good low cost epoxy resin source...
PostPosted: Wed Oct 09, 2019 12:33 pm
by tony.latham
I quit polyester resin at least twenty years ago. I used Raka's six-quart epoxy kit for my entire teardrop.
It's about as easy as buttering toast. Almost.
