Page 1 of 1
Innegra fabric on foam
Posted:
Mon Oct 19, 2020 7:06 pm
by Aussie leslie
Okay has anyone used Innegra fabric on foamies before , what are your thoughts on it . Just right now I can buy 135 GSM 1100mm wide by the meter at $4-95 Aussie dollars it is tuff and lightweight fabric it's on special sale at the moment as I am typing this
Re: Innegra fabric on foam
Posted:
Tue Oct 20, 2020 4:46 am
by GPW
Got a sample ???
Posted:
Tue Oct 20, 2020 6:05 am
by Pmullen503
What adhesive would you use?
You really don't need exotic fabrics for a foamy. They are not exploding at highway speeds or blown down by gusts of wind.
Posted:
Tue Oct 20, 2020 6:37 am
by RJ Howell
Had to look into that a bit.. Replaces fiberglass and stronger by weight it seems. Also quite expensive... Uncertain if it finishes any easier or easier to apply.. I see no reason why it couldn't be used since it epoxies on.
Looks like a good product if you require going 'super' lite and 'should' give durability.. Interesting product!
Posted:
Tue Oct 20, 2020 3:07 pm
by Aussie leslie
The reason I have been looking at it is I drive a Diahatsu terios they only have a 1.3 liter motor so my Teardrop has to be super light , I have a friend who is going to build one with me for himself he's building an aluminium chassis for his we are both trying to go ultra light .
PS They use it in USA to build Hurricane and tornado shelters so if you built your Teardrop with it you could hop in your Teardrop and be safe .
Posted:
Tue Oct 20, 2020 7:58 pm
by tony.latham
Posted:
Wed Oct 21, 2020 4:29 am
by GPW
We’ve tried Spectra fabric in the past … It’s TOUGH , almost impossible to cut with scissors or knife and
bullet proof … pricy too … Probably many fabrics that would work for covering trailers …
Posted:
Wed Oct 21, 2020 9:38 pm
by Aussie leslie
Bullet-proof now that sounds good safe inside in a cyclone or hurricane or tornado but how much is it?
Posted:
Thu Oct 22, 2020 3:28 am
by GPW
Bit pricy , but probably similar coin to Innegra … best check on that !
