Whoops! I bought 1.5" walls instead of 2"
Postby dotrosedotnet » Sun Dec 13, 2020 12:39 pm
Will my foamie suffer from this? Should I try to replace it before I tackle the walls in the coming days?
Thanks so much for all the help!
dotrosedotnet
Re: Whoops! I bought 1.5" walls instead of 2"
Postby pchast » Sun Dec 13, 2020 9:01 pm
1.5 worked for me........ :thumbsup:
pchast
Images: 97
Postby GPW » Mon Dec 14, 2020 4:50 am
If you find areas “thin” , you can always add extra foam ( scraps ) like foam gussets in corners and foam “ arches” on the roof … :thinking:
Postby KCStudly » Mon Dec 14, 2020 10:03 am
1.5 works nicely because it is really close to 2 inch (nominal) dimensional lumber. I say "really close" because the actual thickness of the foam varies quite a bit with the OEM tolerance.
Postby dogcatcher » Mon Dec 14, 2020 3:53 pm
You have also gained 1" in length and width on the inside.
dogcatcher
