Page 1 of 5
#5
PostPosted: Fri Jul 09, 2021 9:28 pm
by ghcoe
Well #4 is done and gone so now onto #5. This build it not a build for a vehicle, but rather a bicycle, to be more exact a E-Bike.
While in the process of selling #3 I was approached by a person who was interested in if I could build a travel trailer for a bicycle under 100lbs. Well good question so challenge accepted. I am currently into this build quite a ways and it does seem that I should easily come in under 100lbs. At this point I am hoping for 75lbs.
Floor with inner frame rails attached.
20210620_073036 s.jpg (504.41 KiB) Viewed 2144 times
Walls mocked up for window placements.
Walls
20210626_104101 s.jpg (359.92 KiB) Viewed 2144 times
Walls #2
20210626_104120_HDR s.jpg (351.71 KiB) Viewed 2144 times
Re: #5
PostPosted: Fri Jul 09, 2021 9:45 pm
by ghcoe
Once I figured out where I wanted the windows I cut them out.
Window
20210627_094126 s.jpg (330.02 KiB) Viewed 2137 times
Then the spackle to smooth things out on the printed side.
Spackle applied
20210703_130206 s.jpg (390.06 KiB) Viewed 2137 times
Then a sanding to smooth the walls out.
Spackle sanded
20210704_083004 s.jpg (465.01 KiB) Viewed 2137 times
Re: #5
PostPosted: Fri Jul 09, 2021 9:51 pm
by ghcoe
Then it was time to cut the canvas to length.
Unrolling the canvas
20210704_085416_HDR s.jpg (404.61 KiB) Viewed 2137 times
Then roll up the canvas and get it ready to be glued down.
Ready for gluing up
20210704_091044_HDR s.jpg (492.45 KiB) Viewed 2137 times
A hour later we have a canvased wall.
Canvas glued down
20210704_104135_HDR s.jpg (441.92 KiB) Viewed 2137 times
Re: #5
PostPosted: Fri Jul 09, 2021 9:58 pm
by ghcoe
Once the canvas is dry I cut back the canvas where glue will be applied for assembly and cut out the windows.
Trim canvas
20210705_094734 s.jpg (481.61 KiB) Viewed 2133 times
Then a quick test fit to make sure the windows fit properly with the canvas installed.
Test fit
20210705_100211 s.jpg (440.61 KiB) Viewed 2133 times
I weighted the wall with the windows fitted at this point, it came in at 11lbs.
Re: #5
PostPosted: Sat Jul 10, 2021 4:22 am
by GPW
8) 8) 8)
Re: #5
PostPosted: Sun Jul 11, 2021 4:33 pm
by skyl4rk
this is gonna be good...
Re: #5
PostPosted: Sun Jul 11, 2021 5:26 pm
by ghcoe
skyl4rk wrote:this is gonna be good...
I was wondering how long it was going to take till you found out... :thumbsup:
Re: #5
PostPosted: Sun Jul 11, 2021 6:55 pm
by ghcoe
Not to much got done this weekend as far as working on the trailer.
I basically only got to cutting the excess canvas off the other wall and prepped up some templates and a hot wire cutter for the shelves.
Shelf cuts marked
20210711_115915 s.jpg (364.48 KiB) Viewed 2028 times
I am adding two shelves to the front of the trailer.
Shelf cuts cut
20210711_125203 s.jpg (371.39 KiB) Viewed 2028 times
Re: #5
PostPosted: Sun Jul 18, 2021 11:24 am
by Terra6
Another fun project. :D :thumbsup:
Have pondered this exact same thing a couple times with an electric bike for touring. If only solar recharge feasable would be the greatest thing ever. Not an expert but my basic understanding is demand use exceeds slow solar recharge capacity. Damn. But going to campgrounds or other 110v source, can charge overnight. Ideal 2 batteries.
Having built many years ago a basic bike trailer from cedar and metal studs to do touring, didn't work out well for me and had to scrap the bike touring thing quickly.
Trailer was maybe 18x30 and light. Great.
Problem was my camping equipment and stuff was too heavy. Didn't have the luxury of ultralightweight gear back in the day.
Hard to pedal, never mind uphill and wind, plus braking hazard from momentum. Especially downhill. Just my experience fyi.
There is a traveler setup like this on YouTube who does this. Think it's corroplast if I remember correctly.
But back to the build.
What will you be doing for axle and wheels? Dimensions? Or did I miss that?
Bike racers measure everything in grams so whatever you can do to the extreme to reduce weight is huge.
Less paint and glue to minimize weight.
So why not a lighter floor than OSB? Would think this is the ideal place for a luaun foam sandwich torsion box that everyone talks about.
And in theory, just the torso or major weight bearing section. The ends could be even lighter, just luaun.
Couple thoughts to ponder.
Re: #5
PostPosted: Sun Jul 18, 2021 12:36 pm
by ghcoe
Terra6 wrote:Another fun project. :D :thumbsup:
Thanks!
I purchased a cargo bicycle trailer to scavenge the axle, wheels and hitch from. It was more economical to do it that way than to purchase them separately.
The dimensions are 7'6"x3'6". I did some research on some trailers that are made/manufactured in Europe and found that the dimensions I came up with were pretty close. There is however no real set way to build a bicycle trailer I found out.
My clients wanted a trailer that was no more than 100lbs. Doing the calculations in my head I figured I could easily come in under 100lbs even using OSB for the floor. I decided that since this was the first build it was probably better to stick with something I knew. Of course that was at the start of the build, but now I may try to lighten the floor since yes there is a lot of weight there. The trailer is planned to be towed behind a cargo e-bike, so I guess they have bigger capacities than a standard commuter e-bike. Most of the standard e-bikes I have looked at have a weight capacity of 275lbs-300lbs.
Re: #5
PostPosted: Mon Jul 19, 2021 9:43 am
by printer
I was part of a team building a solar car racer. The cars were all built low and flat with the maximum area for solar cells. The cars were also allowed to sit and charge the batteries at the end of the day with the cars tilted to face the sun. Just looked up solar bikes.
https://electrek.co/2018/09/27/solar-po ... e-journey/
Re: #5
PostPosted: Mon Jul 19, 2021 9:50 am
by printer
Thanks!
I was considering use a Baltic Birch sandwich with foam in between for my trailer but went with plywood. One inch foam and 1/8" plywood might be lighter. I measured the Mahogany plywood I have and it is lighter than Birch. Maybe a ply top and wrapped bottom?
Re: #5
PostPosted: Tue Jul 20, 2021 9:46 am
by JazzVinyl
[quote="Terra6"]https://electrek.co/2018/09/27/solar-powered-electric-bicycle-journey/[/quote
WOW!! I would never have imagined that an 8,000 mile electric bicycle trip, was possible!
Paint me, amazed :-)
All they sell here, in bike shops these days, are (about $2000.00) electric bikes. 20 miles or so, is the max you can expect to get from their rigs, Out on the local bike paths, the electric bikes are going so fast, that it is absolutely frightening to us pedal power riders.
Re: #5
PostPosted: Sat Jul 24, 2021 7:52 pm
by ghcoe
Progress this week.
Applied canvas to the ceiling side of the roof panel.
Applying canvas
20210718_081203 s.jpg (464.43 KiB) Viewed 1808 times
Canvas applied
20210718_085930_HDR s.jpg (443.01 KiB) Viewed 1808 times
Once dried I trimmed the excess canvas off.
Canvas trimmed
20210719_070042 s.jpg (393.2 KiB) Viewed 1808 times
Re: #5
PostPosted: Sat Jul 24, 2021 7:58 pm
by ghcoe
I had forgot to cut out the left wall shelf dados the week before so I had to cut those out.
Cutting dados
20210719_075940 s.jpg (437 KiB) Viewed 1806 times
