Can I do this in foam?
Postby Gator417 » Tue Apr 12, 2022 11:16 am
"A couple years ago I purchased an Aerostar (E4WD) for a camper project. PO insulated it, installed some solar panels and an inverter and used it for camping until he blew a head gasket.
My plan was to fix it, tweak it a bit and do the same until it got smashed by a tree. From the doors forward is still fine but the cargo area got hit pretty bad.
I think maybe I can cut the rear out and convert it to a mini-RV. Has anybody here done this? I'm not even sure which area to look for info about it."
I posted this in GD, twice apparently, but haven't gotten any feedback. I'd super like to do this in foam/pmf to save weight and make it more durable and rot resistant etc. Any similar projects I can borrow some ideas from? I have a lot of it semi-built in my head but I'm not sure where to start.
Thank you,
Gator
"Aluminum skinning is to cover rotting prone crappy plywood"
linuxmanxxx
Gator417
Re: Can I do this in foam?
Postby ghcoe » Tue Apr 12, 2022 6:10 pm
You can check out this thread. I think it is pretty close to what you would be doing.
viewtopic.php?f=55&t=71251
George.
ghcoe
Postby saywhatthat » Tue Apr 12, 2022 8:33 pm
you'd be surprised what a few pictures would do for you :pictures:
Il suffit de le faire
viewtopic.php?f=50&t=73945
saywhatthat
Images: 135
Postby RJ Howell » Wed Apr 13, 2022 7:25 am
I had the same questions as I designed my Truck Camper. 168576
I thought of doing a sort of SIP but didn't want the plywood skins and couldn't get enough info on just using fiberglass as the skin. I see a few folks doing it now. I like what I'm seeing, but.. not totally convinced... yet.
I ended up doing a Skelton frame, but I also have a full length/width lift top and the over-cab loft. If I had built solid to the cab & full height (no lift) I would have gone for it. My lift roof is just fiberglassed XPS (with one strut made of the same) and found I need more. Here in the Nor'East we get snow and I got caught in a storm and it concaved, didn't break though.
I will be testing a another way to build it basically inserting a vertical rib in a rout every 16". Thinking now of using FRP material I have around.
In all, yes I say it can be done. The process needs to be worked through, then do it on or off the vehicle and install. Being a van.. and being a big fan of lift-tops.. you ever thinking of popping the top instead of building it tall?
Best of on your project!
RJ Howell
Images: 36
