Insulation value of laminated XPS
Postby kstills » Fri Jan 06, 2023 1:40 pm
Will there be any change in the R value of the XPS once it's sealed with either PMF or Expoxy-Glass? I would think there would be, however I'm sure there's folks here more knowledgeable than I on the subject.
kstills
Re: Insulation value of laminated XPS
Postby linuxmanxxx » Fri Jan 06, 2023 3:04 pm
Every item has some type of r value so it slightly raises it. We have some extreme heat in Texas and even 3/4"is quite effective in smaller spaces compared to solid wood walls and the same thickness.
Sent from my Pixel 6a using Tapatalk
linuxmanxxx
Images: 10
Postby kstills » Fri Jan 06, 2023 3:33 pm
linuxmanxxx wrote:Every item has some type of r value so it slightly raises it. We have some extreme heat in Texas and even 3/4"is quite effective in smaller spaces compared to solid wood walls and the same thickness.
My concern is that by sealing the foam you would lower the R value, since you won't be allowing an exchange of air. I get that there will be 'some' exchange, however what I don't know is how much you need in order to hit the R value that the foam is rated for.
kstills
Postby linuxmanxxx » Fri Jan 06, 2023 3:45 pm
As long as you limit pass thru things say like metal or wood things that have inside and outside surfaces with no foam between would lower it. If only outer or inner things exist it doesn't lower.
linuxmanxxx
Images: 10
Postby tony.latham » Fri Jan 06, 2023 7:32 pm
...since you won't be allowing an exchange of air.
That's one reason insulation works. You want to stop conduction and convection. Moving air is convection.
Postby QueticoBill » Fri Jan 06, 2023 7:46 pm
Generally, all insulation works better when tightly enclosed and no room ( as little as 1/8") for air to move.
QB
QueticoBill
Images: 22
