Guts of the matter...hard or soft flooring on the inside?
What type of flooring did you use inside your T or TTT? And why?
Hard floor...painted
3
8%
Hard floor...sealed plywood
10
28%
Hard floor...laminate
1
3%
Hard floor...vinyl
11
31%
Soft floor...carpet
7
19%
Other...(more creative than me!!!!)
4
11%
Total votes : 36
Postby Miriam C. » Sun Dec 23, 2007 10:22 pm
Dave I put floor finish on mine but it shows. I made the door as a temp so Had a gap and water got in. Sure glad I sealed the daylights out of it. If you epoxy it you probably don't need to poly over it. I mean how much sun will get inside. Do finish the galley though.
Also if you decide to vinyl you still need to seal the ply first.
If you are gluing the walls down I would leave off the sealer where the glue will be. MHO 8)
oh yeah and if you epoxy the edges where the sides and floor meet it won't let water in either. :thumbsup: ;)
Postby Steve_Cox » Sun Dec 23, 2007 11:54 pm
I over did it on the floor inside. Dark Oak Parquet. Never see it because of the mattress. Just more added weight, labor and expense. But it does look nice. 8)
Steve_Cox
Images: 196
Postby Ptomaine » Fri Jan 11, 2008 7:21 pm
I have exercise/shop mat (the cushiony stuff with the jigsaw puzzle edges that hold the sqares together). It added just that little bit of extra cushion for my less than adequate (but free) matress.
As you grow up and leave the playground where you kissed your prince and found your frog.
Remember the Jester that showed you tears The script for tears.
Ptomaine
Return to User Polls
