What is in a door why did you pick that design?
What shape is you door and why did you pick it
doors we have to have doors ... I know I forgot something.
4
18%
They were sold in that shape so ...... that is why
0
No votes
it came that way with them already on
6
27%
I wanted something different.
12
55%
Total votes : 22
Postby GeorgeT » Mon Mar 06, 2006 11:16 pm
I wanted a door that was easy to seal, thick enough not to have warping problems, large enough to pass through easily and have a more secure lockset. It is simply two pieces of 1/2 inch birch plywood laminated together with 1x2 trim all the way round to cover the plywood edges and stiffen it up a bit more. It's a little on the heavy side but swings nice, has nice solid shutting sound and helps with tongue weight. The wife appreciates the locks. :eyebrows:
The little overhang trim over the door helps divert rain. The underside of the overhang has a 1/8" groove cut into the underside to keep the water from creeping toward the door gap.
Lookin' up in da skize with ize on da prize
http://home.earthlink.net/~g.teague/
GeorgeT
Return to User Polls
