HEAT
Do you use a heater ?
Poll ended at Sat Jan 13, 2007 4:48 pm
GAS?
1
3%
Electric?
12
40%
Don't camp in the cold
2
7%
Don't need heat
5
17%
the significant other
4
13%
da Dawgs
2
7%
12v mattress pad
4
13%
Total votes : 30
HEAT
Postby BnTRanch » Sat Jan 06, 2007 4:48 pm
We use a 12vdc heat pad under the mattress cover and preheat the bed before getting in for about 40 minutes. I used this in my tractor when I was truckin'.
But now I have added a roadpro 12vdc heater to take the chill off in the morning in the tear. Takes no time at all to remove the chill.
Road Pro 12 Volt Heater Defroster RPAT-858
BnTRanch
Postby Kevin A » Sat Jan 06, 2007 4:55 pm
Looks like a neat little heater, nice price too.
http://boatandrvaccessories.com/HEATER-FANS.htm
Kevin A
The other guy
Images: 289
Postby Nitetimes » Sat Jan 06, 2007 5:11 pm
Make you own heat, it's cheap (more or less) and fun. ;) ;) :) :lol: :lol:
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby len19070 » Sat Jan 06, 2007 5:22 pm
I have an LP heater, but have never needed it for heat. Its used more for drying things out from damp/rainy days. We're going out Feb 9-11 and don't expect to use it.....But I'm still bringing it along.
Happy Trails
Len
len19070
Images: 24
Postby madjack » Sat Jan 06, 2007 5:23 pm
BnT...I added a couple of more options to your poll...I have found a need for heat yet but the coldest camping done so far was 38*s and with the wife and a couple of mutant chihuahuas it would have to get a good bit cooler to need a heater..I have a similar 12vdc heater I got from HF and a small 120vac ceramic heater if ever I should find a need for one...the heated (12vdc) mattress pads are an attractive alternative (power consumption wise) to the Road Pro type heaters.....
madjack 8)
PS....WARNING...never sleep in a completely closed up TD, regardless of weather...or it may be a very looooooooong sleep!!!!!!!!!!!!!!!!! always allow for some ventilation.........
I have slept
Postby BnTRanch » Sat Jan 06, 2007 5:34 pm
down to -25F (truck idled all night ) and that pad made it Very comfortable indeed.
Well worth it in my opinion
Terry
BnTRanch
Postby Lazybones » Sat Jan 06, 2007 8:12 pm
I voted significant other. When I had a significant other I wondered why anyone would want a heater in there teardrop. Now that I sleep in the trailer alone it does get cold at times. a twelve volt blanket sound good for breaking the chill. Where can I get one?
Is it true? Is it necessary? Is it kind? Ask yourself these simple questions every time you are in doubt about any action.
Lazybones
Images: 49
Postby madjack » Sat Jan 06, 2007 8:38 pm
http://boatandrvaccessories.com/HEATEDBLANKETS.htm
http://www.electrowarmth.com/
...local Wal-Mart hadda selection of them in their bedding section last nite as well.................
madjack 8)
Postby Kens » Sat Jan 06, 2007 8:59 pm
We camped in 30 deg and needed heat. We got a 120vac mattress pad hope thats enough. If not we may just stay home?
Good day every day!
Kens
Images: 26
Len does not need heater
Postby Guy » Sat Jan 06, 2007 10:59 pm
Dear Len,
You do not need the heater because you sleep INSIDE the hunting lodge 3 feet FROM A HUGE FIRE., while Jack and I are twenty feet away in another room where fereezing cold water has to keep running all winter or the pipes bust.
But it was great and more than worth the trip.
Regards,
Guy
Guy
Images: 44
Postby Lazybones » Sat Jan 06, 2007 11:00 pm
Thanks Madjack!
I am going to order one from the link you gave. :woohoo:
Who says you need a girlfriend.$>
Lee
Lazybones
Images: 49
Postby bledsoe3 » Sun Jan 07, 2007 3:54 am
Lazybones wrote:Thanks Madjack!
Lee
That mattress warmer will cost a whole lot less than a date. And if that leads to something more, never mind. We don't need to go there
bledsoe3
Images: 112
Postby madjack » Sun Jan 07, 2007 4:15 am
Lee, the RoadPro models are more along the line of a heated lap blanket...the ElectroWarmth models are heated mattress pads and would probably work better as a heater substitute...truckers luv 'em........
madjack 8)
Return to User Polls
Users browsing this forum: No registered users and 28 guests
