What Does Your Teardrop Trailer Weigh?
Postby traveler » Tue Jun 10, 2008 10:57 pm
Fully loaded mine weights 1020 lbs. :)
Why do anything unless it is fun with your teardrop
traveler
Postby AmyH » Thu Jun 12, 2008 3:05 pm
Mine is about 5X9 1/2 and a bit taller than normal. I have fiberglassed/epoxied 3/4" plywood sides, 3/4" framing skinned with 1/8" ply on the inside (insulation throughout), and two 1/8" layers of ply on the roof, also epoxied. I just had it weighed yesterday, and it came out to 1280 lbs. The cabinet face frames and the water tank, etc... are not in yet, so I am guessing that when all that is in it will be closer to 1350 lbs. It's a bit on the heavy side, but my Outback pulls it with no problems.
Amy
"...follow humbly whereever and to whatever abyss Nature leads, or else you shall learn nothing." T.H. Huxley
Photo Log
Camping Trips with the Tear
AmyH
*The 300 Club
Postby Roly Nelson » Sat Jun 14, 2008 12:54 am
I have 2 tears. The 4x8 woody weighs 450 lb. My 40" x 72" Stacker weighs in at a mear 245lbs..........
Roly ;)
Roly Nelson
L'il Ol' Woody Builder
Postby Jst83 » Sun Jun 14, 2009 9:08 pm
Finally after 3 years got mine weighed on my way to camping this weekend,
1720 lbs fully packed. Better than I thought it would be 8)
Jst83
Images: 215
Postby Shadow Catcher » Thu Aug 20, 2009 6:38 am
Our Mega-Mini 6' by 11' dry weight 1150 weighed on a truck scale.
Images: 217
Postby JenniferandPups » Thu Aug 20, 2009 8:06 am
TTT, 7x10 foot body, 1480 including full propane tanks and all dishes/pans, but NOT including water (or food or bedding or the little portapotty).
Pulled with a Subaru 2.2L wagon... fine, except the clutch. Going to pull with a 4 cyl Ranger. Auto, so no clutch to kill.
JenniferandPups
Images: 5
Postby nevadatear » Thu Aug 20, 2009 8:32 am
1100 lb loaded. 5 x 10 with 3/4 wood sides. No propane tank. Including water.
Owner,Desert Metal Products. Custom machine shop. Inventory of thousands of bearings and seals, from the common to the archaic.
nevadatear
Images: 145
Postby Creamcracker » Thu Aug 20, 2009 9:51 am
At a local scale 820lbs with a 60lb tongue weight.
Philip
Creamcracker
Teardrop Graduate
Images: 142
Postby dwgriff1 » Thu Aug 20, 2009 10:43 am
My 5 by 8 insulated and lined, but frameless, 580.
dave
dwgriff1
Postby mechmagcn » Mon Oct 12, 2009 11:26 am
My 5X11 steel framed, aluminum skinned w/ full galley weighs in right at 1600lb. This is ready to camp, food, ice, the works. A little heavier than I really wanted, but that's what it is :oops:
Jeff & Micki
53 F100
Mercedes turbo diesel
Teardrop "finished" as if they ever are
You can never be lost if you don't care where you are going!
mechmagcn
Images: 56
Postby Shadow Catcher » Mon Oct 12, 2009 1:24 pm
Our 6 by 12 Mega-Mini dry weight 1150 lbs actual with full propane tank. Next MM will be 1250 with added items.
Images: 217
Postby caseydog » Mon Oct 12, 2009 1:36 pm
I still need to get mine weighed, but based on the materials that went into it, I estimate that it weighs around 600-700 pounds. It is a 4X8 Benroy style.
CD
My build journal is HERE
caseydog
Images: 515
Postby bohemian » Wed Oct 14, 2009 7:19 pm
Mine weighs in at 1450lb dry. Wood is heavy.
bohemian
Images: 233
Postby S. Heisley » Wed Oct 14, 2009 8:50 pm
There are two teardrop weight threads that I can find. This particular one that we are writing in now was started in 2004. The other one is here:
http://tnttt.com/viewto ... c&start=45
Maybe we can combine them into one somehow? Dunno.....maybe this post is all that is needed to point people to the other....?
Also, another one on material weights is here:
http://tnttt.com/viewto ... ht=#569700
I know there are a couple more but trying to wade through the search engine and all the posts to find them al is a major task.
Maybe what we need is a poll where people enter the size and weight of their trailer? …Or is there one that I missed?
Images: 491
Postby Sparksalot » Wed Oct 14, 2009 9:24 pm
Rose is 1300# give or take.
5x10 woody.
Done? Surely you jest. A teardrop is never "done".
Sparksalot
Images: 579
Return to User Polls
