Running water in your galley?
Yes I'll be installing a sink and running water
I'll install running water only
25
33%
I'll install a sink without running water
8
11%
I'll install a blue poly aqua-container with water
26
34%
1 gallon jugs is plenty for me
17
22%
Total votes : 76
Postby Q » Sun Apr 15, 2007 8:14 pm
Originally I installed a 15 gallon plastic tank, a faucet, electric pump, and small stainless steel sink. I found I needed counter space more than I needed the almost useless little sink. Later I removed the sink, faucet, and pump and installed a gravity tap outside on the lower back of the trailer. This works much better IMO. Just put a bucket under the tap to collect the water when washing, etc.. Kick the bucket under the trailer when not in use.
The 15 gallon tank has been great during extended boondocking.
Q
Q
Postby Ron Dickey » Wed Apr 18, 2007 11:20 pm
Dang,
you guys got me thinkin. I have a sink I got at HD on clearence and plan a sink but I have a huge empty space between the top and the bottom of my frailer about 3 inchs I might put a tank there on one side and a durty water one on the other side. put in hoses that I can unscrew when I remove the upper trailer from the lower.
(does that mean I have a convertable?? :roll: )
Ron D.
121377......134179
Ron Dickey
Images: 711
Postby Nic » Wed May 30, 2007 10:20 pm
I was thinking about a gravity fed sink from a tank up high in my closet. Any thoughts on that? :thinking:
Im not lazy. I just hang out a lot.
Nic
Images: 169
Postby bledsoe3 » Thu May 31, 2007 1:08 am
Nic wrote:I was thinking about a gravity fed sink from a tank up high in my closet. Any thoughts on that? :thinking:
How big of a tank? Water is heavy. You wouldn't want too much weight up high. IMO.
...didn't the original Ken-Skils (or maybe Modernistic) have a 4" thick, 7gal tan,k mounted hi in the back of the galley witha gravity fed faucet.....
bledsoe3
Images: 112
Postby Arne » Thu May 31, 2007 7:45 am
may have replied before.. water only on the picnic table. none in the galley. don't want it, don't need it.... too little space.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby Nic » Thu May 31, 2007 11:34 am
Im not sure. At first thought im thinking a thin flat tank that i can bolt to the top of the closet. 4'ish x 2'ish. Maybe 4-6" tall. Im not sure. And maybe a fill cap on the roof of the camer. I want a sink and running water but im not sure how to do it without taking up too much storage room. If i dont go gravity fed im going to use a manal pump with a tank in the floor.
Nic
Images: 169
Postby madjack » Thu May 31, 2007 12:53 pm
...sorry about that Jim :oops: seems I hit the edit button instead of the quote..............
Postby bledsoe3 » Fri Jun 01, 2007 1:21 am
madjack wrote:...sorry about that Jim :oops: seems I hit the edit button instead of the quote..............
Just don't let it happen again. :lol:
bledsoe3
Images: 112
Return to User Polls
