video's for learning do you use them
do you use video's to lean for building or repairing camping equipment?
yes
17
61%
no
11
39%
Total votes : 28
Re: video's for learning do you use them
Postby halfdome, Danny » Thu Jul 05, 2012 12:30 am
Ron Dickey wrote:They say playing music helps your memory, I need to learn to read music .... there is a piano in the house. and a gi-tar too.
Camping is ment to be fun and you are in the right direction. As long as your music does not run the folks next door the wrong way. ;)
Nice new hobby. :thumbsup:
I go off somewhere by myself and practice or play inside the teardrop with the doors closed.
Just old Rock N Roll songs like "House of The Rising Sun" etc. :D Danny
halfdome, Danny
*Happy Camper
Images: 188
Postby Ron Dickey » Mon Aug 20, 2012 9:27 pm
here some more builds
http://www.youtube.com/watch?v=wSuLYxQOfl4
Bruce Osborn built a standy type but you get an idea of how to do some cabinets, I beleave I saw it at IRG my photos were blurry. You will like the video.
add a room idea
http://www.youtube.com/watch?v=M4tg_wud ... creen&NR=1
http://www.youtube.com/watch?v=S-SHVAit ... creen&NR=1
bike trailers and push type all lite and might have parts useful in our trailers.
want to take along a spare room for guests? think about it.
http://www.youtube.com/watch?feature=fv ... fuOFGMk2_8
If you want to build light bike trailer not sure if it peddles or motor. but def. different wish they talked less and showed more.
http://www.youtube.com/watch?v=82n5TlubZ1c
a cartoon of a sort bike trailer fills one with ideas
http://www.youtube.com/watch?v=MDmXunG1RVc
IRG 4.0
http://www.youtube.com/watch?v=koeFGPQXbmU
IRG 4.0 video I get to act it this one Lucia and I are the last folks videoed in this movie.
121377.............134179.........134805
both side walls are up...cabinet needs stain.......ongoing 2.5 yr bld build as i find time..... Cross Bow in Build Journals....viewtopic.php?f=50&t=54108
Ron Dickey
Images: 707
Postby Ron Dickey » Fri Jan 04, 2013 10:07 pm
some times new idea for how things look or are made makes one wonder what new thing they can do with a TD.
http://www.youtube.com/watch?v=32kK7lQZSks
You will not believe this one.
Ron Dickey
Images: 707
Postby Ron Dickey » Tue Apr 02, 2013 10:14 pm
I am going to build a Galley one day and this youtube will help me build the frames for the drawers and cabinets
http://www.youtube.com/watch?v=W2eiT6dbR4k
Biscuit Jointer seems to be a tool Woodworkers use. It is a very very dangerous machine but does a really cool job.
I have been looking for other videos that will help me with cabinets
can any one offer some good ones.
In a teardrop the drawers would not be the depth of one in a house. or would it.
Ron
Ron Dickey
Images: 707
Postby halfdome, Danny » Wed Apr 03, 2013 7:50 am
Ron Dickey wrote:I am going to build a Galley one day and this youtube will help me build the frames for the drawers and cabinets
Ron
Ron, I worked several years in the face frame department at a California cabinet shop.
In my opinion a biscuit cutter is not the best method to build face frames.
You'd be better off with a self centering doweling jig and a bag of 3/8" x 2" spiral dowels.
The dowels penetrate each member 1" and all that gluing surface makes for a very strong joint.
Any member over 1 1/2" wide should get 2 dowels to prevent racking.
Personally I don't have one since I've owned an industrial pneumatic single spindle doweling machine for several decades.
I just step on the foot petal and the hold down foot comes down & it drills the hole.
You could make one if you have a radial arm saw.
Just put a drill chuck into the screw on the side of the motor.
Purchase a 25/64" brad point bit to go into the chuck.
Don't use a 3/8" bit or the glue could crack your wood, use the 25/64" bit.
Swing the motor so the drill bit is facing you, then build a fence to go into the fence slot.
Make a paddle for a hold down using a spring loaded screen door hinge.
Accurately mark off your center hole and the width of your rails on the fence.
Now you can drill holes by pulling the saw toward you.
I did that for several years and it worked great.
Your next best method would be a pocket jig and screws.
The ultimate would be a mortise & tendon joint but it's so labor intensive.
You'll be just fine with dowels or pocket screws.
There's no hard rule that you can't go face frameless.
I only make face frames for the cabin and go frameless in the galley, which affords more useable space.
The depth of your drawers are dependant on the available space in your galley.
Make a full sized layout to determine your drawer depths.
:D Danny
halfdome, Danny
*Happy Camper
Images: 188
Postby Ron Dickey » Mon Apr 08, 2013 11:43 pm
:D Danny
Danny next gathering I am going to take a close look at your cabinets :twisted: :D
Ron
Ron Dickey
Images: 707
Postby Gregdickinson » Mon May 20, 2013 5:36 pm
Shadow Catcher wrote:I have had problems with written instructions all my life, particularly if they are not clear and it appears to be an aspergers thing. Yes you do have to be careful as a good percentage is garbage but in many cases I find Youtube videos helpful.
I sure can relate to that! I try to use as many things as I can to compensate, such as video's, pictures and asking allot of questions.
Greg
Gregdickinson
Images: 7
Postby Java Jack » Tue Mar 17, 2015 3:26 pm
Since we did not build a teardrop, we did not use any videos for that. However, I regularly use videos to learn all sorts of stuff. Whenever I work on a car, I search youtube first if it is a repair I have not done before.
I also create/post my own videos on repair jobs and reviews so others can learn from my experience.
There are 10 types of people in this world, those that understand binary and those that don't.
Regards,
Java
Proud Owner of a CampInn 560 Ultra
Blog: http://cre8tiveapps.blogspot.com/
Video: https://youtu.be/TLLFt3vzFoA
Sill Images: http://imgur.com/a/EE0zC#0
Java Jack
Return to User Polls
