If you were to build it all over again ...
If you were to build it all over again, what's your main reason for rebuilding?
I really wanted better quality
29
14%
I really wanted it longer
16
8%
I really wanted it taller
8
4%
I really wanted it wider
43
21%
I really wanted it lighter
33
16%
I really wanted a woodie
6
3%
I really wanted a vintage looking aluminum one
7
3%
I really wanted a more modern looking one
1
0%
I really just want to purchase a factory model
6
3%
Other, I'll add my note below!
52
26%
Total votes : 201
Postby Ron Dickey » Mon Jul 26, 2004 2:13 am
Each day new idea come in, new designs, old tears reappear, someone does it different and you like it even more. Also there are a certain number of people who are in the 2nd teardrop club, for a reason...
If you started over, or if you would start over what would your main reason be?
121377.............134179.........134805
both side walls are up...cabinet needs stain.......ongoing 2.5 yr bld build as i find time..... Cross Bow in Build Journals....viewtopic.php?f=50&t=54108
Ron Dickey
Images: 707
Postby mikeschn » Mon Jul 26, 2004 5:43 am
If I hadn't built such a heavy one the second time around, my answer would have been, I wanted it wider!!!
Images: 479
Postby Chip » Mon Jul 26, 2004 7:35 am
After almost finishing my first tear I there are a number of things I would do completely different,,A number of thes changes would make the construction process run smoother and the end result a lot nicer,,ya got to build one or maybe even two before it really all starts to click together..
I am overall happy with my first build but #2 would (will) be different than the first.
chip
54"x9'4" tear
4'x8' tear
Chip
Images: 49
Postby tdthinker » Mon Jul 26, 2004 10:44 am
I really want a woddie although I will most likely paint, I have a large tear design so most likely I would want it lighter. Prob is if it is lighter it is usally smaller.
Ryan
tdthinker
Postby shil » Mon Jul 26, 2004 11:25 am
I made a few mistakes I'd like to correct; I voted for 'Better Quality'.
It's only the first time once.
shil
Postby Guest » Mon Jul 26, 2004 11:00 pm
"Other"
Because I sold it, or someone stole it.
Guest
Postby beverlyt » Mon Sep 06, 2004 8:56 am
I would want it wider.
And I would have done that from the start, had I found this forum right away and had there been plans available.
To date, noone sells step-by-step plans for a 5' wide teardrop.
Bev
beverlyt
Images: 20
Postby BufordT » Wed Sep 08, 2004 1:30 am
I started out building a grasshopper. Was much too big for a first attempt.
I ended up with a mini-hopper. Close to what Mike's weekender looks like.
My next one will be either a weekender or a more traditional design with modern style.
But either way there will be a third one down the road.
Bufordt :twisted:
"RUSH" The Man, The Legend, The Way Of Life.
BufordT
2nd Teardrop Club
Images: 23
I you were to build it all over
Postby pdart70 » Tue Sep 21, 2004 9:38 pm
I think I would make it ( will make the next one) wider. Weight not really a problem.
"Make them laugh or Make them cry, Either will ensure they remember you!"
P.D.Wilburn
pdart70
Images: 9
Postby Arne » Wed Sep 22, 2004 4:53 am
With having gained more knowledge, I would do the following:
- use a h/f trailer, widened to 5 ft, lengthened to 10 ft (the current 104" is just adequate).
- I would not make it as tall (56"), I would stay with 48"
- I would put in a footwell (to still have headroom for a table)
- replace stock spring/axle with torsion axle
- not build it in one month. this was done out of necessity. If I build another, I won't have to rush it. It does take a toll....
re the above, I can still put in the footwell and replace the axle. I am not at all unhappy with the way my first tear is turning out, with more time and planning, it just could have been tweaked a bit to make it 'more better'.....
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby SteveH » Mon Nov 08, 2004 7:45 am
I LIKE this thread. Didn't vote, because I've not built a Teardrop, but it gives me a "heads up" on what NOT to do. Would love to see more input here.
SteveH
SteveH
Images: 42
Postby Joseph » Mon Nov 08, 2004 8:10 am
I'd have used a wooden frame w/bolt-on axle like the original rather than an HF frame. I'd have also built the hatch first and built the walls to fit rather than trying to fit the hatch to the walls.
Joseph
Joseph
Teardrop Pirate
Postby campadk » Mon Nov 08, 2004 9:14 am
I couldn't vote either... We're pretty happy with what we have, although a bit more vintage look is on the wish list (replacing fenders next spring).
Was surprised to see that 'I really wanted it wider' is 29% of the vote. Wider for the cabin? or galley or both?? True 4ft is a bit cozy. I think the ideal width is 54 inches. I would have thought more would vote for 'I really wanted it longer' which I found was more of an issue then width.
campadk
Teardrop fun specialist
Images: 34
Postby Steve Frederick » Mon Nov 08, 2004 10:13 am
Bigger, Lighter construction methods, creative opportunity! I'll fix things that I did wrong...and make some new mistakes,,,so,,,I'll build the next one smaller,,lighter,,more creative opportunity,,,Could go on and on and on.. :wink: :wink: I'll probably just keep building something. It's just what I enjoy! Maybe I'll build for someone else? Anyone? I'm looking forward to retirement, in 8-10 years. I am very cranky without something to work on. :evil: :evil: OR...A fleet for any mood! :twisted: Loaners for friends. :wink:..I'll need more money...Oh Boy!!!
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
Postby Woody » Mon Nov 08, 2004 1:06 pm
Even though it is not an option on the poll. Beyond making it wider, I would have thought thru my electrical system better on the layout and access for maintenance (removable access panels) and adding additional circuits easily without having to reinvent the wheel. I thought that I had it covered by adding extra wires in the original design and still have a clean install. Extra 120 vac outlets and expansion of the 12 vdc system to accomodate future upgrades. I can still do it but now it is more difficult
Woody
E-mail: tearjerkerfla@bellsouth.net
Woody
Images: 26
Return to User Polls
