Coolest thing on forum?
Postby ctstaas » Fri Aug 01, 2014 12:44 pm
I have seen a lot of super cool ideas on this forum and want to thank you in advance for the designs I'll corrupt later. If I had to pick the coolest thing I've seen lately it would be the cooler holder mounted in the receiver. Another idea I really liked was the running boards. What have been your favorites?
Enjoy, Chris
ctstaas
Re: Coolest thing on forum?
Postby WoodSmith » Fri Aug 01, 2014 12:48 pm
Linky please?
WoodSmith
Glen Smith
WoodSmith
Images: 14
Postby nevadatear » Fri Aug 01, 2014 2:25 pm
Don't know if it is ours that he is referring too, as there are several, but here is ours. Image
Owner,Desert Metal Products. Custom machine shop. Inventory of thousands of bearings and seals, from the common to the archaic.
nevadatear
Images: 145
Postby WoodSmith » Fri Aug 08, 2014 9:01 pm
Could be...
I think that the thing that I (currently) like best is a thread I just discovered and marathoned. http://www.tnttt.com/viewtopic.php?f=2&t=58690
A quick digest:
Premade fiberglass corner pieces in several standard shapes allowing you to create many different profiles of campers. Just order what you need and use locally available plywood for the walls and roof. Similar to the curves at the front and top corners of cargo trailers / box trucks.
WoodSmith
Glen Smith
WoodSmith
Images: 14
Return to User Polls
