bedding what bedding did you use inside?
What soft cozy thing are you sleeping on ... bedding only.
Air mattress
11
14%
bed mattress
17
22%
Styrafoam stiff to med to soft
12
15%
memory foam
23
29%
sleeping bag pads
2
3%
my own special design
3
4%
I am not telling the doors are shut and you need not know.
2
3%
see below
8
10%
Total votes : 78
Postby Ron Dickey » Wed Mar 01, 2006 11:13 pm
The whole reason for these high fangled trailers is mostly to get a better sleep then a tent.
And the most important part of all is if you are not sleeping on the floor what you are sleeping on.
We will talk about food later ... :cry: I know you built it so you could get steak and eggs, waffles with blue berry syrup, Beer and Wine and every thing fine but after much too much what do you crawl off to?
121377.............134179.........134805
both side walls are up...cabinet needs stain.......ongoing 2.5 yr bld build as i find time..... Cross Bow in Build Journals....viewtopic.php?f=50&t=54108
Ron Dickey
Images: 702
Postby PaulC » Thu Mar 02, 2006 1:00 am
4" high density foam. The first night was unusual but after that we adjusted. Best nights sleep I've had out bush.
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
Location: Laura, Souther Flinders Ranges, South Australia
Postby jje507 » Thu Mar 02, 2006 1:09 am
6" thick futton mattress. sleeps good and easy to remove when I need to.
jje507
Images: 16
Postby doug hodder » Thu Mar 02, 2006 1:40 am
Knox foam with a zippered cover...4" medium.. and I put a 1.5" eggcrate foam under it....I like it...and so does the better half!! :thumbsup: ....Doug
Postby mikeschn » Thu Mar 02, 2006 6:24 am
Knox Foam, Grade A, medium, with their custom covers, and a feather bed on top.
Images: 479
Postby SteveH » Thu Mar 02, 2006 7:54 am
4" Knox Foam and 1 1/2" Memory Foam in a Knox Foam cover. GREAT! I recommend it.
SteveH
SteveH
Images: 42
Postby mikeschn » Thu Mar 02, 2006 7:58 am
Oh yea, I also have a 4" mattress, with 2" memory foam on top, all covered by a beautiful zipperd cover... affordably priced at Walmart...
Check out similar discussion here...
http://tnttt.com/viewto ... 5644#45644
Images: 479
Postby Clancy Courtney » Thu Mar 02, 2006 9:40 am
I used a 4" mattress taken from an small travel trailer. It folds and is a perfect fit.
Clancy
Clancy Courtney
Images: 11
Postby Ma3tt » Thu Mar 02, 2006 11:01 am
4" hi density foam, wool blankets and down comforter toasty!
Be Good
1967 Siesta del Sobrino "Standy"
If you lived here... you would be home by now.
http://www.Camp-Cook.com
Ma3tt
Dutch Oven GURU
Images: 179
Postby 48Rob » Thu Mar 02, 2006 1:15 pm
Inner spring Futon mattress.
Futon style because it is so much easier to bend to get in and out.
Inner spring for serious comfort.
Rob
Visit Rob's World Web Page!
48Rob
Postby Lazybones » Mon Mar 06, 2006 12:38 am
I had a custom futon made to fit my trailer. It is more comfortable than my bed at home. One great thing about a futon is that is is so easy to get in and out of the trailer.
Is it true? Is it necessary? Is it kind? Ask yourself these simple questions every time you are in doubt about any action.
Lazybones
Images: 49
Postby Guest » Mon Mar 06, 2006 12:46 am
mikeschn wrote:Oh yea, I also have a 4" mattress, with 2" memory foam on top, all covered by a beautiful zipperd cover... affordably priced at Walmart...
Mike,
Is that in four sections, (for the dinette) with the feather thing used only when it's made up as a bed, or did you nix the dinette and just go one piece?
Guest
Postby bg » Mon Mar 06, 2006 12:52 am
I'll be using a air mattress for now, hopefully replaced by a foam mattress later this summer.
Hard to justify a $200 mattress in a $500 teardrop.
Bobby(, Kim & Wayne)
bg
Postby asianflava » Mon Mar 06, 2006 12:59 am
I used the 6in Wal Mart foam mattress. I guess it's the same one Mike mentioned, 4in foam with 2in memory foam in a zippered case.
asianflava
Postby mikeschn » Mon Mar 06, 2006 5:17 am
Dean in Eureka, CA wrote:Mike,
I'm planning on cutting it up into 4 pieces... However, it's such a nice mattress, I may just buy some knox foam instead.
Images: 479
Return to User Polls
