what tools did you use
Tools used other then the basics to build
Designed on computer
3
3%
Designed with paper and pencil
4
4%
Started with paper and pencil then moved to computer.
4
4%
hand saw
6
6%
power saw
10
10%
table sawl
8
8%
router
10
10%
Laser cutting tool
0
No votes
scroll saw power , hand
4
4%
paint brush
11
11%
power spray paint
2
2%
power or hand miter saw
6
6%
Dremel big and little
5
5%
Grinder
8
8%
some one else's plan
1
1%
Router Table
1
1%
Router
7
7%
Band saw
4
4%
Planner hand or machanical
2
2%
sheet metal snips
2
2%
Bender
1
1%
heat gun
2
2%
Total votes : 101
Postby Ron Dickey » Fri Jun 10, 2022 12:09 am
A Side from the small toolslike screw drivers, hammars what tools did you use in your build
121377......134179
Ron Dickey
Images: 711
Re: what tools did you use
Postby swoody126 » Fri Jun 10, 2022 2:28 pm
when i click'd on VOTE the software spit it back
i use too many tools for it's likin'
sw
swoody126
Postby working on it » Fri Jun 10, 2022 4:16 pm
* I used a (not listed) Roto-zip instead of some other tools, to cut out windows, vent openings, A/C opening, and the doors (because I already owned one), and the main tools I used also weren't listed.
* Since I used steel brackets (plus PL adhesive) to clamp the plywood together, I used a 7/16" "combo" (box/open) hand wrench, a 1/4" drive cordless impact with 7/16" socket, and a cordless 3/8" drill with a 1/4" bit the most (I bolted it together using mostly 1/4"-20 stainless carriage bolts, stainless fender washers, and stainless locknuts). The cordless impact and drill were used wherever any screws were needed, too. I started my project using my friend's Snap-On tools at his shop, and bought my own cordless Milwaukee tools when I finished the trailer at my garage. I don't know how I would've done the project without them.
* Another necessary item, not listed, is a welder. My original frame was enlarged and strengthened using the friend's Mig welder, then when I re-did my frame and axle a couple of years later, I did it at my garage with a 110v flux welder (I also bought a 220v unit, but never used it). Lots of builders need one, even if just to modify a frame, just a bit.
* Other necessities: multi-meter, soldering iron, wire cutter-crimper, a BFH, and miscellaneous hand-tools deserve a place on your list, also.
173193172890148599
working on it
Images: 457
Postby JasenC » Sat Jun 11, 2022 8:35 am
I used Sketchup to sort out the basic dimensions and a few finer points, but the design is largely in my head. I build a lot of stuff just out of my head and it's not as random as it may sound, it's just how my mind works. Yes, yes I am an alien.
At this point in my build it's just been a welder, grinder, ratchets and wrenches. But as a home remodeler there will be plenty of other tools, besides my table and band saw I'll use my jointer and planer and the Sprinter I drive for work is full of construction tools. On top of all those tools I have enough of my own woodworking and construction tools to pretty much outfit another Sprinter.
I'll be done when I'm finished, if that's not fast enough, take a number.
Build Thread https://www.tnttt.com/viewtopic.php?f=50&t=74269
JasenC
Images: 122
Postby tony.latham » Sat Jun 11, 2022 8:16 pm
You need to add a drill and a drill driver... and a 1/4" pneumatic stapler to your list. ;)
I'd be lost without mine. :frightened:
Postby S. Heisley » Sat Jun 11, 2022 8:27 pm
Drill is missing and Router is in there twice.
Postby tony.latham » Sat Jun 11, 2022 11:54 pm
Welder...
Postby Ron Dickey » Mon Jun 13, 2022 6:39 pm
Sorry I have not made the User Poll site in years.
All that mater is that folks read what you used that I left out
The way tnttt are made now a days make me look :scratchthinking: twice.
Thank you for helping me with the site, and may it help others make their work shine.
Ron
121377......134179
Ron Dickey
Images: 711
Postby johnvan » Thu Jul 07, 2022 1:57 pm
Curious what people think about routers... I will be picking up my trailer kit tomorrow, then supplies and any remaining tools needed.
I don't have a router yet. I'd like to stick with one of the smaller DeWalt palm routers. The DWP611 is corded and about $150 (and I have a coupon from Northern Tool that will cover its entire cost :D ), and the other is the DCW600B 20V cordless which is about $170 on Amazon. Unfortunately, the cordless isn't carried at Northern Tool so I would need to pony up the cash for that.
I don't foresee using it a lot beyond this and a few other projects (probably some frames, etc), but is the ease of the cordless worth biting the bullet on? Thanks for any advice you can give...
john
johnvan
Postby Philip » Thu Jul 07, 2022 2:08 pm
John a small hand router is a good item to have. A larger heavy router is good for a permeant mount in a router table not much good for fine detail type of work.
Philip
Images: 323
Postby tony.latham » Thu Jul 07, 2022 4:14 pm
I don't foresee using it a lot ...
I've got two battery systems in my shop. Makita and Dewalt. And I have at least three routers (maybe four?) --and none of my routers are cordless.
I'd get a Dewalt DW616. That little one you are looking at will do a lot... but it's a trim router. I've got it on my CNC. I would suggest the DW616.
:thinking:
Postby friz » Thu Jul 07, 2022 9:38 pm
I just buy as I need. For my camper build the only tool I added was an orbital sander. Cheap B&D from Wally World.
Sent from my SM-S906U using Tapatalk
The "Sin Bin"
150133
friz
Return to User Polls
