Hall of Fame boo boos
Hall of Fame entries
Postby ratjack1 » Wed Jun 20, 2012 9:32 pm
I struggled to post my teardrop picture on the HOF. I finally figured it out but now have two blank posts and the final correct version. How
do I delete the boo boos? These would be the Teardrop tribute by Ratjack.
ratjack1
Re: Hall of Fame boo boos
Postby mikeschn » Thu Jun 21, 2012 3:40 pm
I cleaned it up for you!
Images: 471
Postby ratjack1 » Thu Jun 21, 2012 4:41 pm
Thanks Mike!
ratjack1
Postby Mitchelkitman » Sat May 11, 2013 6:56 am
I received a post from Mike a few weeks ago requesting photos of my Quantumsleep for the HoF. I did as directed, but I'm unable to get them on HoF - sorry but I just can't work out how to do it.
Martin
Mitchelkitman
Postby working on it » Sat Aug 17, 2013 7:38 pm
Mitchelkitman wrote:I received a post from Mike a few weeks ago requesting photos of my Quantumsleep for the HoF. I did as directed, but I'm unable to get them on HoF - sorry but I just can't work out how to do it.
Martin
Although I wasn't asked to submit a photo, I tried it anyway, twice. I can view the photo, but the caption says (Edit), and the link to my gallery is broken. What did I do wrong?
  • 2013 HHRv,"squareback/simple" TTT, semi-offroad? 4x8, 2000+ lbs travel weight
  • featuring:
    • 3500 lb Dexter axle,
    • 27x8.5-14LT tires,
    • LED lighting,
    • A/C & heat,Optima AGM battery,
    • extended-run 2500w generator,
    • Coleman dual-fuel stove & lantern
  • 147697148333125895
  • 148599148106
working on it
Images: 427
Postby working on it » Fri Aug 23, 2013 8:56 pm
Martin
Since I never received a reply to this post, I assumed it couldn't be fixed. However, I checked it without logging in and all was well; I guess that everyone sees the photo and links correctly, only I (who doesn't need a link) do not when logged in. I guess I was reporting a problem that didn't exist for others. Sorry.
  • featuring:
    • LED lighting,
  • 148599148106
working on it
Images: 427
Postby Wild Idaho » Sun Nov 30, 2014 12:46 am
I think (I hope) I'm having the same issue. I don't see my picture but hovering over where the picture should be takes me to my album so I hope it works correctly. I'd really like to see my picture though. I copied and pasted the image url but I can't see it. Any suggestions on how to resolve the issue? Thanks, Jeff
Wild Idaho
Images: 91
Return to Hall of Fame
