Hard wall popup
Hard wall popup
Postby icematrix » Tue Feb 10, 2015 4:58 pm
I've been toying with designs for a hard walled popup with minimalistic architecture for some time. I like the idea of a camper with a view for scenic sites.
I have the donor trailer (an old tent camper trailer) and I've begun sketching designs on top of the trailer dimensions.
Chad
icematrix
Re: Hard wall popup
Postby KCStudly » Tue Feb 10, 2015 6:53 pm
Nice renderings. :thumbsup:
Welcome to the forums.
Any thoughts on methods and materials of construction, and specifics on how you will seal the upper and lower halves together? :thinking:
Re: Hard wall popup
Postby icematrix » Tue Feb 10, 2015 7:00 pm
I plan on using aluminum square tube for the framing. The walls will be skinned with aluminum on the outside, then a layer of foam. On the inside the materials vary from hardwood ply to sheet metal. I will probably use VHB tape and construction adhesive wherever visible to avoid lots of fastener holes.
I will use guides at the corners to keep the halves in line, and front and rear linear actuators coordinated by a microcontroller to do the actual task of raising and lowering.
There will probably be some sort of stiff brush material or a rubber gasket in the gap between halves to keep nature out. I need to do some more research on that.
I plan to use this for spring and summer camping only, and keep it garaged in the winter.
icematrix
Re: Hard wall popup
Postby KCStudly » Tue Feb 10, 2015 7:08 pm
Cool. Mind sharing a little of your background? Sounds like you are in some sort of technical industry and obviously have design skills.
Re: Hard wall popup
Postby icematrix » Tue Feb 10, 2015 7:41 pm
I'm just another nerd. Computer programmer, systems admin, network engineer, web designer, I do a bit of everything.
I like to do woodwork and metal fab for fun. I've built or restored lots of things from furniture to vending machines.
Here is some of my recent stuff in no particular order:
Hexagonal Greenhouse
Donkey Kong
60's Vendo Coke Machine
icematrix
Re: Hard wall popup
Postby icematrix » Tue Feb 10, 2015 7:46 pm
Concessions Stand
Lemonade Stand for my kids
Little Free Library for the community garden
icematrix
Re: Hard wall popup
Postby icematrix » Tue Feb 10, 2015 8:03 pm
Ok, I know it's off topic, but one more. This is a little Trade Stimulator (slot machine) that I restored for my father's birthday a few years ago.
Before:
And After:
icematrix
Re: Hard wall popup
Postby KCStudly » Tue Feb 10, 2015 9:38 pm
Very nice! Thanks for sharing. :thumbsup:
Re: Hard wall popup
Postby icematrix » Sun Feb 15, 2015 9:33 pm
I originally was going to just have an outdoor shower. But lately I have been toying with the idea of a small wet bath like the T@b and the aliner.
Any opinions on the value of having one of those little baths?
icematrix
Re: Hard wall popup
Postby OP827 » Thu Jun 11, 2015 12:36 am
This is a cool idea, camping with a view in urban modern style... Looks like if you aim for urban style "glamping", the inside bath could be in order, right? I have no experience using those wet bath, never had one like that, sorry, but I like your ideas. :applause:
OP827
Images: 405
Re: Hard wall popup
Postby DrewsBrews » Fri Aug 07, 2015 2:39 pm
Very neat idea!
Any precautions you would take to prevent it becoming your second greenhouse?
DrewsBrews
Re: Hard wall popup
Postby Gladtobehere » Fri Aug 07, 2015 4:15 pm
Have a look at the Alto by Safari Condo. I think they are gorgeous but a little to expensive for my blood.
http://www.safaricondo.com/en/caravanes
Gladtobehere
Re: Hard wall popup
Postby BigGoofyGuy » Tue Sep 08, 2015 8:32 am
icematrix wrote:I've been toying with designs for a hard walled popup with minimalistic architecture for some time. I like the idea of a camper with a view for scenic sites.
Chad
I think that is way cool. :thumbsup:
BigGoofyGuy
Location: Newburyport Massachusetts United States of America
Re: Hard wall popup
Postby fm-usa » Sat Jan 16, 2016 6:50 pm
Chad
CHAD:
When you design these up, do you consider the gross weight?
If you do, give us your thoughts.
We're interested.
Is it possible, FULL RV in a 48 Sq.Ft. footprint & stay under 500Lbs wet?
SHE thinks teardrops are "cute" but I prefer a SKOSH mo-room & at 65+ the
body doesn't react/extract/move/mend/bend/lend or work like it use'ta.
NOW! Those unwanted guests moving in, Mr. 'Arther I. Tus' & Ms. DVT (grrr)
fm-usa
Location: ILLinois_60085 ================= Floyd_&_Debbie_+_Bailey
Re: Hard wall popup
Postby mallymal » Sat Sep 10, 2016 5:08 pm
Coolest thing ever, and probably the most modern design on the forum I've ever seen!
I guess you would need some kind of soft rubber gasket to seal the pop up bit. Im assuming your huge windows are some kind of plastic... I would just worry about scratches on those when elevating the top....
mallymal
Images: 18
Return to Sketch up designs
