Little Guy RT Design
Postby Kit76 » Wed Apr 11, 2018 6:21 pm
Has anyone drawn up a Little Guy RT design? Or Built one?
Don't Sweat the Petty Things, Don't Pet the Sweaty Things
Kit76
Images: 60
Re: Little Guy RT Design
Postby irgod32 » Wed Apr 11, 2018 9:22 pm
This would be my guess, it's 48" X 96" side walls. You can use a compass to round the corners on the side walls or use 5gal bucket lid and trace the corners. Seems like a simple design. The front may be 18" instead of 14", you'll have to play with the height on the front and you'll have to consider the height of the mattress from inside. There is no galley so no worries there. The lighting should be easy both inside and out.
What I love about these small trailers is that you can tweak a design to make it your own. Draw it out on a Masonite 4' X 8' board and see what you like. You'll notice that on the front, I rounded off both front corners, so design away my friend!
I hope this helps :thumbsup:
153838
Tiny Trailer Builders of America
Build it and they will come
irgod32
Images: 56
Postby Kit76 » Thu Apr 12, 2018 8:18 am
That Does Help. I appreciate it!
Kit76
Images: 60
Postby greygoos » Thu Apr 12, 2018 8:27 am
Use the search bar above and look for reverse tear. Here are some specs for Little Guy RT
Width (Cabin): 62"
Length (Cabin): 96"
Width (Fender to Fender): 82"
Length (Tongue to Bumper): 13'-0"
Weight: 940 lbs.
Tongue Weight: 120 lbs.
(2) Side Sliding 20" x 30" Windows
(1) 26" x 32" Rear Entry Door
Front End Storage Area: 60" x 12"
Aluminum Roof Rack
Rear Bumper
greygoos
Postby working on it » Thu Apr 12, 2018 12:34 pm
irgod32 wrote:This would be my guess, it's 48" X 96" side walls... Seems like a simple design. ...What I love about these small trailers is that you can tweak a design to make it your own. Draw it out on a Masonite 4' X 8' board and see what you like....
  • The Little Guy RT is a good-looking variant of the "simple" design,m with rounded corners/edges for aerodynamic streamlining, in lieu of the normal teardrop shape. irgod32 constructed his "simple" variant with rounded front corners for some aero benefits, but the rear remains predominantly square, as does my TTT. I wanted to build mine using simple, straight cuts, as much as possible, sacrificing the streamlined teardrop shape entirely. THe Reverse Tear has kept rounded corners on top, but squared on the bottom, and with a large square/flat rear, so it's somewhat more aero than irgod32's trailer, and significantly more than mine.
    simple-style, offroad & semi-offroad TTT's.jpg (189.62 KiB) Viewed 5108 times
    simple-style, reverse vs. conventional forward entry TTT's.jpg (200.08 KiB) Viewed 5108 times
  • But, the Reverse Tear departs from the conventional teardrop, or even the "simple" squareback TTT design, by having no rear galley/storage area (mine is storage only, with no room for cooking!), and puts a single entry door at the rear, instead of a hatch accessing the galley, on the side(s), like more conventional designs. It's a good way to get into the cabin, if one is not limber enough to enter/exit a side door (at 67, with bad knees and back, my TTT is getting sorta difficult for me to get in or out now), but then the trailer is unable to to serve as a cooking area, or have a large storage compartment onboard (there is small side compartment for storage, though...perhaps a slide-out "kitchen/countertop could be installed there?).
  • Since a lot of teardrop/TTT campers use canopies and/or attached side tents for sheltered cooking areas, or for clothes-changing/porta-potty rooms, the rear entry door could have a similar set-up, underneath one canopy? (I use one or two canopies, and one or two side tents, having two doors and a rear hatch, with extra side-tables and cooking stand, to cover... lot of things to put up or takedown at camp). As I see it, the Reverse Tear (or clone) should be a good design alternative to more conventional types of small camping trailers, provided that you are prepared to camp lightly, or have extra storage and cooking options available to you.
173193172890148599
working on it
Images: 457
Return to Sketch up designs
