Exterior Plywood Type Question
Finishes, paints and coatings
Postby Metalhead » Wed Sep 24, 2014 2:40 pm
Been researching and can't seem to find the answer I'm looking for so I'll post my question here for feedback.
My exterior siding plans so far are Outside Plywood -> Epoxy -> Fiberglass Cloth and Epoxy -> Product such as Monstaliner. My concern is with the base plywood. I have seen people mention baltic birch for woody's as well as some other builds. Is this type of plywood entirely necessary for what my plans are, or would a hardwood plywood be sufficient as long as it's sealed and coated as I mentioned above.
P.S. This question was also posted in my build thread here.
--Metal
Metalhead
Images: 7
Re: Exterior Plywood Type Question
Postby George Taylor » Wed Sep 24, 2014 7:30 pm
If you are going to have a smooth and painted finish, which I will assume, all you will need is a good quality plywood that has a exterior grade glue. I would find a lumber yard, not HD or Lowes, and ask them. You will pay slightly more but they get better stuff. MDF plywood might work and has a very smooth finish to start with.
George Taylor
Return to Skinning secrets
