.090 Aluminum Sheet
Finishes, paints and coatings
.090 Aluminum Sheet
Postby Chaos Smurf » Mon Mar 23, 2015 12:37 pm
Hello All,
I've been lurking for awhile soaking up all the great information. I've read the skinning threads and know .040 aluminum is the sweet spot.
I have an opportunity to buy .090 aluminum sheets.
5x12 .090 Aluminum Sheets
5052 Thickness is .090 and is an 11 gauge
for $75 CDN per sheet
Would I be able to bend this around a 54" bend radius?
Chaos Smurf
Re: .090 Aluminum Sheet
Postby bobhav » Mon Mar 23, 2015 2:58 pm
That sounds like a heck of a deal. While I have not worked with .090" 5052, that radius is doable. 5052 is stiff. It may require a form of sorts to bend around. It will take some help. I would make a 54" radius template and find a fab shop with a roller to bend it.
BobH.
Chaos Smurf"]Hello All,
Would I be able to bend this around a 54" bend radius?[/quote]
bobhav
Postby Redneck Teepee » Mon Mar 23, 2015 4:34 pm
That's pretty close to a 3/32" thickness, just under, if that's the only radius you need any sheet metal shop with a 5' wide roll could pre-form it with no problem. Hell for stout, not to mention heavy if your looking to keep it light. Like Bobhav say's take a template to make one accurate trip out of it.
:D :D :D Good luck on your build!
Redneck Teepee
Images: 21
Postby Chaos Smurf » Mon Mar 23, 2015 5:12 pm
Thank you,
I'm going to think about it some more.
Chaos Smurf
Postby Gunguy05 » Tue Mar 24, 2015 12:55 pm
Chaos Smurf wrote:Thank you,
Please, don't buy this.
Long after you have forgotten about what the Al for you build cost, it's weight will still be there..
I used .040, and really could have gone .032. .090 has got to be insanely hard to work with, not to mention over twice as heavy.
Just my 2 cents.
Brian
Checkout my buildThe Regal Eagle Bow front for 4
Also my teardrop updates from blog on Dad Rambles
Gunguy05
Images: 6
Postby dustboy » Sun Mar 29, 2015 9:29 am
Agreed. Unless you are building a zombie shelter, it will be needlessly heavy and you'll be fighting it on every curve.
dustboy
Images: 10
Postby mjewell5 » Tue Sep 22, 2015 1:52 am
We use .090 on some of the structure of the A-10's that I work on. That stuff is extremely stout! In fact, we walk on it! It would be a real bitch to bend without using rollers, and would be about 3 times as heavy as .032. Except for the great deal, I can't see a reason to go with something that thick. Stick with .032 or .040.
mjewell5
Images: 14
Return to Skinning secrets
