ACM Panel weight
Finishes, paints and coatings
ACM Panel weight
Postby 1TallTXn » Thu Jul 30, 2015 5:27 pm
In my quest to find info about the ACM panels, I hunted and finally found details on the weight of this stuff.
I would have liked a table, so I made on here for us.
Source: http://www.ullrich-aluminium.co.nz/roll ... panels.php
Extrapolating the data, this is what I found.
Given:
1m^2 = 10.71ft^2
1kg = 2.20lbs
2mm ACM = 2.9kg/m^2 ~= 6.4lbs/m^2 ~= 0.59lbs/ft^2
3mm ACM = 3.8kg/m^2 ~= 8.37lbs/m^2 ~= 0.78lbs/ft^2
4mm ACM = 4.8kg/m^2 ~= 10.58lbs/m^2 ~= 0.98lbs/ft^2
For comparison, 3/4in plywood weighs about 61lbs or roughly 2.85lbs/ft^2
source: http://theplywood.com/weight
I'm sure I'm not the only nerdy one that wanted to know.
*I make no claim for this to be accurate across all brands/types. Treat it as a rough guess, get the specifics from the one you are buying, and go with that.
--Nathan
I'm from Texas, what country are you from?
I like pretty much anything that has buttons, and engine, and/or goes boom.
1TallTXn
Return to Skinning secrets
