hartk1213 wrote:When I skin the trailer with aluminum is there anything I need to do to seal the plywood, I know that I should use some sealant around the edges of the aluminum when I put it on butbi just want to know if I need to apply urethane to the edges of the wood or if I could just paint it or if i need do to anything at all?
Thank you in advance
-Hartk1213
Having had a commercially built teardrop that managed to have problems with water along the wall edges in the galley, I've got strong feelings about this. I think most if not all commercial trailers fail sooner or later because water gets inside the walls. It's an area where us homebuilders can easily set a higher bar.
I use Raka thin epoxy (127?). Two coats. Epoxy is the choice for wooden boat builders. It's not that expensive and is easy to apply with a squeegee. I buy their pumps for measuring. Their three coat kit will do a drop. And epoxy the floor of your galley... sooner or later you'll spill something in there.
http://store.raka.com/3quartkit.aspxThe other option, in my book, is to use several coats of "The Mix", a highly diluted polyethylene oil based varnish. It has a great following on this forum. I'd feel comfortable with either method but will stick to epoxy.
