Bed Liner as an exterior coating?
Finishes, paints and coatings
Postby paulnb57 » Sat Mar 05, 2016 5:40 pm
Anyone used Upol Raptor truck bed liner as an exterior coating on a wooden skin?
Seems CPES should be used first, opinions or experiences welcomed....
paulnb57
Re: Bed Liner as an exterior coating?
Postby kayakdlk » Sat Mar 05, 2016 7:43 pm
No but I used Monstaliner rolled on over epoxy and fiberglass cloth. It has worked great and is flexible, durable, used by the Jeep comunity, easy to power wash, has no rubber crumbles in it and and can be waxed. You can read comparisons here http://www.monstaliner.com/monstaliner_comparisons.htm
Dan
kayakdlk
Images: 392
Postby mjewell5 » Sat Mar 05, 2016 10:03 pm
How well would stickers stick to it? I might consider it if I can apply vinyl stickers on it. Also, does it hide irregularities in the substrate?
mjewell5
Images: 14
Postby halfdome, Danny » Sat Mar 05, 2016 10:09 pm
This teardrop was done in bed liner and I didn't see any aging of it over the years that the builder owned it.
:D Danny
halfdome, Danny
*Happy Camper
Images: 225
Postby paulnb57 » Sun Mar 06, 2016 7:49 am
Can't get Monstaliner this side of the pond.....
paulnb57
Postby ArtMini » Sat Apr 16, 2016 9:43 am
halfdome, Danny wrote:This teardrop was done in bed liner and I didn't see any aging of it over the years that the builder owned it.
:D Danny
Can this coating be painted over an oil based primer/sealer? Or Bare wood? I have already sanded and primed most of the trailer and was planning on painting it with regular house paint. But I'm reconsidering this. I really don't want to sand the whole trailer to bare wood if I don't have to.
HAVE FUN STORMING THE CASTLE!!!!
ArtMini
Images: 16
Postby ArtMini » Sat Nov 19, 2016 10:46 pm
:D Danny
Update: 11/19/16, This is what I used to seal my trailed, Dupli-Color Bed Armor, DIY truck bed liner. Just slop it on and everything's sealed. :D
ArtMini
Images: 16
Postby rowerwet » Mon Nov 21, 2016 1:04 pm
bed liner is heavy and expensive, if you want something super durable, but much less expensive, check out the PMF idea.
Mine is 5 years old, and lives outside, it is showing no wear, cracking or looseness, has never been repainted, and uses regular old exterior paint
rowerwet
Images: 521
Postby ArtMini » Tue Nov 22, 2016 3:39 pm
Ok I get "PMF" is "poor man's fiberglass" but what exactly is it? I asked about fiberglass back when I started and everyone told me don't use It because it will eventually crack. So what did you use. Just in case I ever build again?
ArtMini
Images: 16
Postby rowerwet » Wed Nov 23, 2016 9:23 am
Paint filled cloth, the full description can be found in my signature links. Under my Instructables.com link
The fabric and paint become a composite much like fiberglass and epoxy resin do.
Much cheaper and less toxic.
http://www.instructables.com/id/Poor-Ma ... -weatherp/
rowerwet
Images: 521
Postby ghcoe » Sat Dec 03, 2016 11:55 pm
Art Mini wrote:Ok I get "PMF" is "poor man's fiberglass" but what exactly is it? I asked about fiberglass back when I started and everyone told me don't use It because it will eventually crack. So what did you use. Just in case I ever build again?
This is a good read on how well "PMF" works. http://tnttt.com/viewtopic.php?f=55&t=67489
George.
ghcoe
Postby El_Ducko » Fri Jan 27, 2017 2:04 pm
Back in the early 2000's people thought it was a good idea to use bedliner on the exterior of their jeep and it weighed them down big time. plus dust gets down in the little crevices and its impossible to get out, giving it a dull appearance.
El_Ducko
Postby rruff » Sat Feb 04, 2017 11:18 pm
El_Ducko wrote:Back in the early 2000's people thought it was a good idea to use bedliner on the exterior of their jeep and it weighed them down big time. plus dust gets down in the little crevices and its impossible to get out, giving it a dull appearance.
Monstaliner is the only one I know of that I would call suitable for this. It's textured but smooth, not grabby or rough. It's on the right in the image.
Heavy? A typical double coat is ~0.13 lb/sq ft. I don't think that's a lot at all, considering the durable layer you are adding. Maybe it would make a decent exterior for a PMF Foamie?
rruff
Postby bdosborn » Sun Feb 05, 2017 1:36 pm
kayakdlk wrote:No but I used Monstaliner rolled on over epoxy and fiberglass cloth. It has worked great and is flexible, durable, used by the Jeep comunity, easy to power wash, has no rubber crumbles in it and and can be waxed.
How many gallons did you need?
Images: 530
Postby kayakdlk » Sun Feb 05, 2017 5:16 pm
I bought a two gallon kit. Thinned it about 10% and rolled on 2 coats.
Dan
kayakdlk
Images: 392
Return to Skinning secrets
