Bonding to fiberglass components with MASTER SEAL NP1
Finishes, paints and coatings
Postby dogscats » Fri May 06, 2016 10:27 pm
I am getting a chance to try doing some thing with the fiberglass components again. I lost out on the curved parts . Forced over time at work.
What I'll have a chance with is more of a square. and flat.
I think it will work on the weekender' nano weekender,modified explorer pod any thing that mostly flat profiles.
My question is has anyone done this.I will be bonding fiberglass to 1/4" luan. If you used used MASTER SEAL NP1 how did it hold up over time
g]
TODAY IS THE OLDEST YOU'VE EVER BEEN,
YET AT THE SAME TIME, THE YOUNGEST YOU'LL EVER BE,,, SO MAKE THE BEST OF IT WHILE YOU CAN, AND ENJOY THIS DAY WHILE IT LASTS
dogscats
Images: 20
Re: Bonding to fiberglass components with MASTER SEAL NP1
Postby Tomterrific » Sat May 07, 2016 6:44 am
Is Master Seal an adhesive? Is it a urethane? Those urethane adhesives are strong if there is enough surface area and most are gap filling. I've used Gorilla glue, PL and urethane caulk with good results. I would think it would bond fiber glass to wood but have no direct experience.
T
Tomterrific
Postby tony.latham » Sat May 07, 2016 8:46 am
"NP1 and NP2 are the industries most popular high-performance exterior grade sealant grade caulks."
It's sold as a caulking material––not an adhesive. I suspect their marketing hype, "most popular" is an exaggeration since I've never heard of it.
Weren't these fiberglass parts sold as a kit over ebay?
You might consider this West System epoxy. It won't fail, but they don't give it away either.
http://www.westsystem.com/ss/six10-thic ... -adhesive/
Postby H.A. » Sat May 07, 2016 11:01 am
Fwiw,
Masterseal just new name of Sonneborn. Part of the BASF empire.
Lots of folks never heard of it as not sold at WalMart or local Homecenter, but very good chance it was used constructing their buildings. Its market aimed toward industrial users & yes, its one of the most popular.
As far as adhesive, its very good. But suitability for a task depends on configuration of the joint & amount of motion between sections. Obviously materials play into as well, its not going to stick well to some plastics, Teflon for example.
H.A.
Postby dogscats » Sat May 07, 2016 12:49 pm
Toney
There a few souses on the web. different profiles . I've got the two profiles one that has one lip the other has two .
It has on the tube polyurethane sealant. There a few tubes in the box I received of glass parts. Also a few tubes of food grade sealer
H.A
I will be using on fiberglass to fiberglass also luna .Also adding some rivets
thank you for the fast replies
dogscats
Images: 20
Postby H.A. » Sat May 07, 2016 1:57 pm
[quote="do !
H.A.
Postby dogscats » Sat May 07, 2016 2:09 pm
H.A
Fiberglass sheeting over Luan ?
The luan will be sealed then bound over the flanges
IF you look close at the picture you can make out the flange that make the shell outside rings
[img]141368[/img]
dogscats
Images: 20
Return to Skinning secrets
